Farid2010 Posted September 24, 2010 Report Share Posted September 24, 2010 I just started to make a Vi project today. All of the sudden when i tried to re-open it , it showed me an error message which I attached here. I also attach my file. I don't know hoe it happened and i would appreciate if you could help me to open it up! Thanks 1.vi Quote Link to comment
Francois Normandin Posted September 24, 2010 Report Share Posted September 24, 2010 I just started to make a Vi project today. All of the sudden when i tried to re-open it , it showed me an error message which I attached here. I also attach my file. I don't know hoe it happened and i would appreciate if you could help me to open it up! Thanks Farid, when you upload code that is not in the same version as the one you show in your profile, please add a note for the version the VI is saved in. I don't have LV2010 installed, so I can't help you. But I wouldn't have tried if there was a note next to your uploaded file. Worst case, if the file is corrupted and the code inside is very complex and hard to duplicate, perhaps NI can help? Quote Link to comment
Farid2010 Posted September 24, 2010 Author Report Share Posted September 24, 2010 Sorry Francois I should have written the version next to it. Farid, when you upload code that is not in the same version as the one you show in your profile, please add a note for the version the VI is saved in. I don't have LV2010 installed, so I can't help you. But I wouldn't have tried if there was a note next to your uploaded file. Worst case, if the file is corrupted and the code inside is very complex and hard to duplicate, perhaps NI can help? Quote Link to comment
jcarmody Posted September 24, 2010 Report Share Posted September 24, 2010 FWIW, I get the same error. Quote Link to comment
SuperS_5 Posted September 25, 2010 Report Share Posted September 25, 2010 Trying to open a reference to the file also fails with the same error. Quote Link to comment
crelf Posted September 27, 2010 Report Share Posted September 27, 2010 Did you remove its front panel? Quote Link to comment
Farid2010 Posted September 27, 2010 Author Report Share Posted September 27, 2010 No i did not!! Did you remove its front panel? Quote Link to comment
ShaunR Posted September 27, 2010 Report Share Posted September 27, 2010 Seems this is a known problem that was fixed in later updates (allegedly). Load Error code 3 Quote Link to comment
PaulG. Posted September 28, 2010 Report Share Posted September 28, 2010 Seems this is a known problem that was fixed in later updates (allegedly). Load Error code 3 " If you are using LabVIEW 2009 these corruptions were fixed with the LabVIEW 2009 f3 patch." Bugs and patches and "Service Packs"! OH, MY! Quote Link to comment
Michael Aivaliotis Posted September 30, 2010 Report Share Posted September 30, 2010 You should be running 2009 SP1 anyway. Quote Link to comment
dannyt Posted September 30, 2010 Report Share Posted September 30, 2010 Seems this is a known problem that was fixed in later updates (allegedly). Load Error code 3 I have tried to open the VI in LabVIEW 2010 running with patch f2 and I get the same error, I suggest you raise a CAR with NI that the problem still exists in 2010 and patch f2 Dannyt 1 Quote Link to comment
