Michael Aivaliotis Posted January 25, 2011 Report Share Posted January 25, 2011 The problem I have is that when I rename the class, I end up with object controls and indicators that contain the label of the original class. Is there an easy way, outside of manually renaming, to do this? Maybe someone has a tool out there? Not sure why LabVIEW doesn't do this for me. I can't be the only one with this problem. 1 Link to comment
Grampa_of_Oliva_n_Eden Posted January 25, 2011 Report Share Posted January 25, 2011 The problem I have is that when I rename the class, I end up with object controls and indicators that contain the label of the original class. Is there an easy way, outside of manually renaming, to do this? Maybe someone has a tool out there? Not sure why LabVIEW doesn't do this for me. I can't be the only one with this problem. Ditto that. Ben Link to comment
Stagg54 Posted January 25, 2011 Report Share Posted January 25, 2011 scripting is your friend. Link to comment
Michael Aivaliotis Posted January 25, 2011 Author Report Share Posted January 25, 2011 scripting is your friend. I figured. Maybe someone can help? Edit: It seems like there is some hope by using the Search and Replace text feature that's built into LabVIEW. I think this will work for now. Link to comment
ShaunR Posted January 25, 2011 Report Share Posted January 25, 2011 I figured. Maybe someone can help? Edit: It seems like there is some hope by using the Search and Replace text feature that's built into LabVIEW. I think this will work for now. There's a few programmatic solutions on this thread Link to comment
Michael Aivaliotis Posted January 25, 2011 Author Report Share Posted January 25, 2011 There's a few programmatic solutions on this thread Thanks. I'll definitely dig into that. Link to comment
Francois Normandin Posted January 25, 2011 Report Share Posted January 25, 2011 Jon's LVOOP Assistant renames Front Panel objects. The LVOOP Assistant supports: - Changing Class Icons themes with native LVOOP colors, custom colors or random colours - Icon Layers due to the integration of the Icon Editor API - Using a Sandbox to create Static and Dynamic methods from user templates - Creating a Constructor method from a user template - Creating Scoped Virtual Folders - Renaming LVOOP FP Object Labels - Cloning a method VI 1 Link to comment
jgcode Posted January 26, 2011 Report Share Posted January 26, 2011 Jon's LVOOP Assistant renames Front Panel objects. Thanks François! That is correct - also the same feature is in the Rename LVOOP FP Object Labels Quick Drop plugin tool (this would be a faster way to go if you only require that feature). Cheers -JG Link to comment
vugie Posted January 26, 2011 Report Share Posted January 26, 2011 The problem I have is that when I rename the class, I end up with object controls and indicators that contain the label of the original class. Is there an easy way, outside of manually renaming, to do this? Maybe someone has a tool out there? Not sure why LabVIEW doesn't do this for me. I can't be the only one with this problem. Here is a plugin for Scripting Sandbox I made for similar purpose. However it is not so friendly to anyone but me... but it is an idea of Scripting Sandbox - isn't it? Replace in-out controls.vi Link to comment
Daklu Posted January 26, 2011 Report Share Posted January 26, 2011 Edit: It seems like there is some hope by using the Search and Replace text feature that's built into LabVIEW. I think this will work for now. I always use the Search and Replace; however, for reasons I haven't figured out sometimes a majority of the labels are marked as being unmodifiable using that feature. Link to comment
PaulL Posted January 26, 2011 Report Share Posted January 26, 2011 I use search and replace, too. It is simple but it would be nice not to have to do this (so maybe I should use of the tools already mentioned, although I think it would be great if NI would incorporate such a feature into the LabVIEW core). Anyway, right now I do a text-based search and limit the search scope to the VIs in the target class. This works well. Link to comment
Michael Aivaliotis Posted January 26, 2011 Author Report Share Posted January 26, 2011 Thanks everyone for the suggestions and comments. In the end, I used one of jgcode's tools. It's funny how, you don't realize the value of the LAVA code repository (or LAVA) until you run into a problem. Link to comment
Stagg54 Posted January 27, 2011 Report Share Posted January 27, 2011 Edit: It seems like there is some hope by using the Search and Replace text feature that's built into LabVIEW. I think this will work for now. That sounds like it might be easier than scripting. In general I find scripting to be a pain to write. Once written it tends to be invaluable, although I find that most of the scripting I write tends to be very narrowly focused and address one specific use-case (maybe it's just me using poor programming practices and not being general enough.) Link to comment
jgcode Posted January 27, 2011 Report Share Posted January 27, 2011 That sounds like it might be easier than scripting. In general I find scripting to be a pain to write. Once written it tends to be invaluable, although I find that most of the scripting I write tends to be very narrowly focused and address one specific use-case (maybe it's just me using poor programming practices and not being general enough.) Scripting is great - but you don't have to create a package and publish it to get an (internal) benefit from it. I suggest you check out Norm's Scripting Springboard - IMHO the fastest way to get a script going. I also like his philosophy on Scripting + Assumptions = Powerful Code. Sometimes, for a project, you just need something quick and dirty, if that does the job and saves you time doing in manually then it is fine that it is narrowly focused. Link to comment
jcarmody Posted January 28, 2011 Report Share Posted January 28, 2011 [...] I suggest you check out Norm's Scripting Springboard [...] I'll add Vugie's Scripting Sandbox as another great place to look. Link to comment
Please sign in to comment
Sign In Now
