MartinMcD Posted August 31, 2011 Report Share Posted August 31, 2011 Hello there, Well, this is strange. I have a program that runs fine in dev mode and has always run fine as a built executable as well. Now I'm getting this strange error which I've not seen before. (The location of the error is valid, one of my vis). I don't suppose anyone else has come across it? I'm in LV2011. A long shot but it'd be great if anyone can help, Thanks, Martin I take that back, I can generate the error in dev mode. Should make life easier. I'll post back once I figure out the issue. Quote Link to comment
crelf Posted August 31, 2011 Report Share Posted August 31, 2011 Is it possible you're going into an infinite (or very very large) loop? Maybe a divide by zero going into the N terminal of a for loop? ...or you're reying to get more data into that task than the buffer can hold? 1 Quote Link to comment
MartinMcD Posted September 1, 2011 Author Report Share Posted September 1, 2011 Thanks, it turned out to be a schoolboy error - one of my variables had reset to zero with the end result (after a division) that I was trying to read a massive number of samples from my DAQ task. Doh! Quote Link to comment
jatinpatel1489 Posted April 13, 2014 Report Share Posted April 13, 2014 Is it possible you're going into an infinite (or very very large) loop? Maybe a divide by zero going into the N terminal of a for loop?...or you're reying to get more data into that task than the buffer can hold? Hello Crelf, I do get the same error with excel report generation. I deal with a large number of data (2 columns with 6 lacs in each). I append such 64 columns in 6 sheets. However to work efficiently I dont write all data at same time rather I append just 2 column at same time. Though during 3rd sheet its starts giving this error. can you please tell me how should I deal with this ?? Your help will be truly appreciated. Quote Link to comment
Rolf Kalbermatter Posted April 14, 2014 Report Share Posted April 14, 2014 Hello Crelf, I do get the same error with excel report generation. I deal with a large number of data (2 columns with 6 lacs in each). I append such 64 columns in 6 sheets. However to work efficiently I dont write all data at same time rather I append just 2 column at same time. Though during 3rd sheet its starts giving this error. can you please tell me how should I deal with this ?? Your help will be truly appreciated. I'm afraid you tax the Excel engine to much. So you say you try to create an Excel Workbook which has 6 worksheets with 64 columns each with 6 million samples? Make the math: 6 * 64 * 6,000,000 = 2.3 billion samples with each sample requiring on average more than 8 bytes. (Excel really needs quite a bit more than that as it has to also store management and formatting information about the workbook, worksheet, colomns and even cells.) It doesn't matter if you do it one sample or one colomn or one worksheet a time. The Excel engine will have to at least load references to the data each time you append new data to it. With your numbers it is clear that you create an Excel worksheet that never will fit in any current computer system. Aside from the fact that Excel had in Office 2003 a serious limitations that did not allow to have more than 64k rows and 256 columns. This was increased to 1048576 rows by 16384 columns in Excel 2007 and has stayed there since. Here you can see the current limits for an Excel worksheet: http://office.microsoft.com/en-us/excel-help/excel-specifications-and-limits-HA103980614.aspx You might have to overthink your strategy about how you structure your data report. What you currently try to do is not practical at all in view of later data processing or even just review of your data. Even if you could push all this data into your Excel workbook, you would be unable to open it on almost any but the most powerful 64 bit server machine. 2 Quote Link to comment
jatinpatel1489 Posted April 14, 2014 Report Share Posted April 14, 2014 I'm afraid you tax the Excel engine to much. So you say you try to create an Excel Workbook which has 6 worksheets with 64 columns each with 6 million samples? Make the math: 6 * 64 * 6,000,000 = 2.3 billion samples with each sample requiring on average more than 8 bytes. (Excel really needs quite a bit more than that as it has to also store management and formatting information about the workbook, worksheet, colomns and even cells.) It doesn't matter if you do it one sample or one colomn or one worksheet a time. The Excel engine will have to at least load references to the data each time you append new data to it. With your numbers it is clear that you create an Excel worksheet that never will fit in any current computer system. Aside from the fact that Excel had in Office 2003 a serious limitations that did not allow to have more than 64k rows and 256 columns. This was increased to 1048576 rows by 16384 columns in Excel 2007 and has stayed there since. Here you can see the current limits for an Excel worksheet: http://office.microsoft.com/en-us/excel-help/excel-specifications-and-limits-HA103980614.aspx You might have to overthink your strategy about how you structure your data report. What you currently try to do is not practical at all in view of later data processing or even just review of your data. Even if you could push all this data into your Excel workbook, you would be unable to open it on almost any but the most powerful 64 bit server machine. Thank you very much for your concern, I actually said each column has 6 lacs(600000) data that makes total 0.23 billion samples and I believe excel can accommodate 600000 rows. I dont know exactly but is this possible ?? Quote Link to comment
ShaunR Posted April 14, 2014 Report Share Posted April 14, 2014 I actually said each column has 6 lacs(600000) data that makes total 0.23 billion samples and I believe excel can accommodate 600000 rows. I dont know exactly but is this possible ?? Now I know what a "lac" is. No. You need a proper database. Quote Link to comment
jatinpatel1489 Posted April 14, 2014 Report Share Posted April 14, 2014 Now I know what a "lac" is. No. You need a proper database. Thank you. Quote Link to comment
LogMAN Posted April 14, 2014 Report Share Posted April 14, 2014 (edited) LavaG is kidding me right now...Again:I would recommend a database, however one of my colleagues implemented something similar in the past (Export huge datasets from an database).You should carefully check the RAM utilization of your System (Do you keep all data in Excel + LabVIEW?).I tested on my machine (LV2011SP1) with 4GB RAM and Excel 2013 using the ActiveX Interface. Writing 64 columns with 600.000 random DBL numbers in a single sheet, one row at a time. It works like a charm, however Excel now uses 650MB RAMEDIT: Just checked what would happen if I build all data in LabVIEW first and then export to Excel: LabVIEW now takes ~1.6GB of memory + throws an error: LabVIEW Memory is fullThe issue is due to the 32bit environment, where a single process can only handle up to 2GB of virtual address space, see: http://msdn.microsoft.com/en-us/library/windows/desktop/aa366912(v=vs.85).aspx The issue is also caused by my way of memory management (reallocating memory each iteration!) Just checked again, I tried to copy all data at once, therefore trying to copy a contiguous block of 64x600.000 array elements (which might not be possible if there is no block large enough to contain this amount of data)... Anyways, the issue is clearly not Excel, but the implementation in LabVIEW (in my case). Edited April 14, 2014 by LogMAN Quote Link to comment
Rolf Kalbermatter Posted April 14, 2014 Report Share Posted April 14, 2014 Thank you very much for your concern, I actually said each column has 6 lacs(600000) data that makes total 0.23 billion samples and I believe excel can accommodate 600000 rows. I dont know exactly but is this possible ?? According to this site a Lakh is 100,000 and a Lac is 10 times more. Maybe there are different Lacs in different areas of India. I personally find it already complicated enough to distinguish between an American billion and an European billion. Don't think I'm going to really memorize the Indian huge numbers that easily, especially if it should turn out that they are not the same all over India. For the rest LogMAN more or less gave you the details about memory management. Since your report generation is interfacing to the Excel engine through ActiveX it is really executing inside the LabVIEW process and has to share its memory with LabVIEW. As LogMAN showed one worksheet with your 64 * 600,000 uses up 650 MB RAM. 3 worksheets already will require ~1.8GB RAM just for the Excel workbook. That leaves nothing for LabVIEW itself on a 32 bit platform and is still very inefficient and problematic even on 64 Bit LabVIEW. 1 Quote Link to comment
hooovahh Posted April 14, 2014 Report Share Posted April 14, 2014 I personally find it already complicated enough to distinguish between an American billion and an European billion. Forgive my ignorance, but are you telling me that 1,000,000,000 American doesn't equal 1,000,000,000 European? EDIT: Wikipedia Quote Link to comment
Rolf Kalbermatter Posted April 14, 2014 Report Share Posted April 14, 2014 Forgive my ignorance, but are you telling me that 1,000,000,000 American doesn't equal 1,000,000,000 European? EDIT: Wikipedia Yep, we use million, milliard, billion, biliard, trillion, trilliard, and so on. Seemed very logical and universal to me until I went to the States! Quote Link to comment
jatinpatel1489 Posted April 15, 2014 Report Share Posted April 15, 2014 I tested on my machine (LV2011SP1) with 4GB RAM and Excel 2013 using the ActiveX Interface. Writing 64 columns with 600.000 random DBL numbers in a single sheet, one row at a time. It works like a charm, however Excel now uses 650MB RAM It works charm with me too till two Excel sheet. But as soon as third come in to picture it starts giving an error. The code uses only 720MB only. It does not have any problem if I bring down number of column data to 0.45M and raise number of sheet. The problem is having 0.6M data in a column and work with 6 sheets. Quote Link to comment
hooovahh Posted April 15, 2014 Report Share Posted April 15, 2014 Yep, we use million, milliard, billion, biliard, trillion, trilliard, and so on. Seemed very logical and universal to me until I went to the States! Thousand, Million, Billion, Trillion, Quadrillion, Quintillion. Each comma is a new unit which is every 10^3. Always seemed logical to me but I've always lived in the US. More info on Wikipedia. Quote Link to comment
LogMAN Posted April 15, 2014 Report Share Posted April 15, 2014 It works charm with me too till two Excel sheet. But as soon as third come in to picture it starts giving an error. The code uses only 720MB only. It does not have any problem if I bring down number of column data to 0.45M and raise number of sheet. The problem is having 0.6M data in a column and work with 6 sheets. Good point! I'll try that again tomorrow with multiple sheets... Does it work better if you save the workbook after each sheet? Quote Link to comment
LogMAN Posted April 16, 2014 Report Share Posted April 16, 2014 OK, here are the latest results:This time I let the application create 6 sheets with 20 columns, 600,000 rows each (writing 2 rows at a time). Notice that the values are of type DBL (same as before). Memory for Excel build up to 1,3 GB, but everything still works perfectly for me. My advice for you is to check if your RAM is sufficient, and review the implementation of the Excel ActiveX Interface. Be sure to close any open references!Without more information of your actual system (RAM) and at least a screenshot of your implementation, it is most difficult to give any more advice. If you could share a sample project that fails on your system, I could test on mine and may check for problems on the Excel Interface. Here is a screenshot of what I did (sorry, but I can't share the implementation of the Excel Interface) Quote Link to comment
Popular Post Yair Posted April 16, 2014 Popular Post Report Share Posted April 16, 2014 Forgive my ignorance, but are you telling me that 1,000,000,000 American doesn't equal 1,000,000,000 European? And this - 5 Quote Link to comment
jatinpatel1489 Posted April 18, 2014 Report Share Posted April 18, 2014 OK, here are the latest results:This time I let the application create 6 sheets with 20 columns, 600,000 rows each (writing 2 rows at a time). Notice that the values are of type DBL (same as before). Memory for Excel build up to 1,3 GB, but everything still works perfectly for me. My advice for you is to check if your RAM is sufficient, and review the implementation of the Excel ActiveX Interface. Be sure to close any open references! Without more information of your actual system (RAM) and at least a screenshot of your implementation, it is most difficult to give any more advice. If you could share a sample project that fails on your system, I could test on mine and may check for problems on the Excel Interface. Here is a screenshot of what I did (sorry, but I can't share the implementation of the Excel Interface) WriteExcelSample.png yeah with 20 column it do work fine however I need to make 64 column in each sheet it does not take much memory in my RAM (700 to 900 MB). My system specification is 8 GB RAM and windows 7 64 bit os. Now If I create 6 workbook it run charm but the problem is 6 sheet in one workbook. Quote Link to comment
Rolf Kalbermatter Posted April 18, 2014 Report Share Posted April 18, 2014 yeah with 20 column it do work fine however I need to make 64 column in each sheet it does not take much memory in my RAM (700 to 900 MB). My system specification is 8 GB RAM and windows 7 64 bit os. Now If I create 6 workbook it run charm but the problem is 6 sheet in one workbook. Unless you use LabVIEW for Windows 64 Bit, you can have 100's of GB of memory and your application is still limited to 2GB of memory maximum. This is inherent to the 32 bit architecture. Due to various components loaded by LabVIEW the limit of usable memory is usually more around 1.3GB. The 2GB is maximum usable memory and there needs to fit in your application, any modules it may use and some temporary management information for LabVIEW and Windows. The Excel plugin being ActiveX doesn't really help this as ActiveX in itself is quite a heavy weight technology. But don't worry, .Net wouldn't be better. 1 Quote Link to comment
LogMAN Posted April 18, 2014 Report Share Posted April 18, 2014 yeah with 20 column it do work fine however I need to make 64 column in each sheet it does not take much memory in my RAM (700 to 900 MB). My system specification is 8 GB RAM and windows 7 64 bit os. Now If I create 6 workbook it run charm but the problem is 6 sheet in one workbook. My bad, I already forgot it had to be 64 columns each page... I've tested again and hit the same limitation on the 32-bit environment (with Excel using up to ~1.7GB of memory according to the Task Manager). Your system is more than sufficient for that operation (unless as rolfk correctly pointed out, you use the 32-bit environment). Unless you use LabVIEW for Windows 64 Bit, you can have 100's of GB of memory and your application is still limited to 2GB of memory maximum. This is inherent to the 32 bit architecture. Due to various components loaded by LabVIEW the limit of usable memory is usually more around 1.3GB. The 2GB is maximum usable memory and there needs to fit in your application, any modules it may use and some temporary management information for LabVIEW and Windows. The Excel plugin being ActiveX doesn't really help this as ActiveX in itself is quite a heavy weight technology. But don't worry, .Net wouldn't be better. This is absolutely right. There is however one thing: Excel runs in a seperate process and owns a seperate virtual memory of 2GB while in 32-bit mode. So you can only create a workbook of that amount, if there is no memory leak in the LabVIEW application. In my case LabVIEW will take up to 500MB of memory, while Excel takes 1.7GB at the same time. If the references are not closed properly, you'll hit the limit much earlier, because LabVIEW itself runs out of memory. In my case the ActiveX node will throw an exception without anything running out of memory (well Excel is out of memory, but the application would not fail if I would handle the error). I have never tried to connect Excel over .NET... Worth a shot? jatinpatel1489: as already said a couple of posts ago: Make use of a database to keep that amout of data. If the data represents a large amount of measurement data, TDMS files are a way to go (I've tested with a single group + channel, with a file size ~7.5GB containing 1Billion values -> milliard for the european friends ). You can import portions of the data in Excel (or use a system like NI Diadem.. I've never used it though). If it must be Excel, there are other ways like linking Excel to the database (using a database connection). Last but not least you could switch to 64bit LabVIEW + 64bit Excel in order to unleash the full power of your system. 1 Quote Link to comment
Rolf Kalbermatter Posted April 18, 2014 Report Share Posted April 18, 2014 I have never tried to connect Excel over .NET... Worth a shot? Well, not sure it provides more options than the ActiveX interface. And there are quite a lot of Excel related hierarchies such as Microsoft.Office.Interop.Excel, Microsoft.Office.Tools.Excel, etc, but only the first one seems to include public accessible contructors for the various interesting objects. Personally I think trying to interface to Excel through .Net is mostly an exercise with little merits other than learning about .Net interfacing. Quote Link to comment
jatinpatel1489 Posted April 30, 2014 Report Share Posted April 30, 2014 (edited) My bad, I already forgot it had to be 64 columns each page... I've tested again and hit the same limitation on the 32-bit environment (with Excel using up to ~1.7GB of memory according to the Task Manager). Your system is more than sufficient for that operation (unless as rolfk correctly pointed out, you use the 32-bit environment). This is absolutely right. There is however one thing: Excel runs in a seperate process and owns a seperate virtual memory of 2GB while in 32-bit mode. So you can only create a workbook of that amount, if there is no memory leak in the LabVIEW application. In my case LabVIEW will take up to 500MB of memory, while Excel takes 1.7GB at the same time. If the references are not closed properly, you'll hit the limit much earlier, because LabVIEW itself runs out of memory. In my case the ActiveX node will throw an exception without anything running out of memory (well Excel is out of memory, but the application would not fail if I would handle the error). I have never tried to connect Excel over .NET... Worth a shot? jatinpatel1489: as already said a couple of posts ago: Make use of a database to keep that amout of data. If the data represents a large amount of measurement data, TDMS files are a way to go (I've tested with a single group + channel, with a file size ~7.5GB containing 1Billion values -> milliard for the european friends ). You can import portions of the data in Excel (or use a system like NI Diadem.. I've never used it though). If it must be Excel, there are other ways like linking Excel to the database (using a database connection). Last but not least you could switch to 64bit LabVIEW + 64bit Excel in order to unleash the full power of your system. Thank you very much for making this clear. Still I am wondering what if I make 6 different workbooks and them combine all them into one. Like I open first workbook and loads data of second workbook into first one. Then close the second workbook open third and append its data into first and so on. Is this possible using labview? It is certain that I can not read entire workbook once rather copying one sheet into another would be feasible. To make clear what am I intending to kindly refer this page. http://smallbusiness.chron.com/merge-excel-worksheets-workbook-54664.html From step1 to step7 Edited April 30, 2014 by jatinpatel1489 Quote Link to comment
LogMAN Posted May 2, 2014 Report Share Posted May 2, 2014 (edited) Thank you very much for making this clear. Still I am wondering what if I make 6 different workbooks and them combine all them into one. Like I open first workbook and loads data of second workbook into first one. Then close the second workbook open third and append its data into first and so on. Is this possible using labview? It is certain that I can not read entire workbook once rather copying one sheet into another would be feasible. To make clear what am I intending to kindly refer this page. http://smallbusiness.chron.com/merge-excel-worksheets-workbook-54664.html From step1 to step7 Your link explains a way to merge multiple sheets into a single workbook. You'll end up with a single workbook containing all data, same as before. The fact that you copy pieces differently does not change the fact that all data will be loaded into memory each time Excel loads the workbook (This is just how Excel works). Since the amount of data is the same, the problem will remain. You'll always experience the same limitations no matter how you build your workbook. Edited May 2, 2014 by LogMAN Quote Link to comment
Rolf Kalbermatter Posted May 2, 2014 Report Share Posted May 2, 2014 Thank you very much for making this clear. Still I am wondering what if I make 6 different workbooks and them combine all them into one. Like I open first workbook and loads data of second workbook into first one. Then close the second workbook open third and append its data into first and so on. Is this possible using labview? It is certain that I can not read entire workbook once rather copying one sheet into another would be feasible. To make clear what am I intending to kindly refer this page. http://smallbusiness.chron.com/merge-excel-worksheets-workbook-54664.html From step1 to step7 In other words to what Logman said: if you have a bag that is to small to put in 6 apples in their own little baggy, then try to put in 1 apple a time without baggy, you still won't be able to to put in all 6 apples! 1 Quote Link to comment
