LabVIEW snippet PNGs are being sanitized
It appears that new snippets (.PNG) files uploaded to lavag are having their meta-data sanitized.
This removes the actual code from the snippet and makes it unusable for drag-and-drop to the block diagram.
  • 2 years later...
Old post, but I am having this problem, too.  How does one post a snippet anyway?  I've tried attaching them to the post, but they get resized, and the embedded code is stripped away.  Not a very good feature for the premier independent LabVIEW web forum.  Is there some other way to add a PNG to the message without attaching it, or clicking the "add to post" button?
Here is an example of a snippet added using the attachment feature of the "More Reply Options" page.  I also used the "Add to Post" link next to the attached file:
post-17965-0-17462700-1432750089_thumb.p
Why does it shrink the image all the way down to a thumbnail?  Most monitors today are huge, with wide aspect ratios, and plenty of resolution.  Why not upload the PNG "as is"?  Most snippets are below one screen in size, and any that are larger will get "resized" for display by the browser.
Also tried the "Advanced Uploader":
post-17965-0-91016700-1432750354_thumb.p
Being able to share snippets without the code getting stripped would be a good thing.
I think I reproduced the steps you took, but I came to a different result.  I posted a reply using the More Reply Options which is also known as the full editor.
From there I picked the file by clicking on Choose File.  Then I clicked Attach This File.  This step might not be needed depending on the version of the uploader that you are using.  Then I clicked Add to Post to add it to my reply.  I was then able to click the image and get the VI source by dragging the image to my desktop.
I wonder if it has to do with the size of the PNG you uploaded.  It obviously scaled it which makes me think there is a maximum resolution the uploader accepts.
EDIT: Yup just tested it, too large of an image is scaled, I'll let Michael know about his and see if there is something that can be done.
Michael worked his magic, that he does so well and things should work now.  I tested it on a pretty large block diagram and my browser zoomed out, but the image itself wasn't scaled on the server side, so I could still drag the snippet away and then into my blank block diagram.
  • 3 years later...
  • 4 weeks later...
  On 12/11/2018 at 5:16 PM, Michael Aivaliotis said:
I think something got changed in the upgrade, but i think i fixed it now.
Expand
Unfortunately it isn't. Can you check again?
Here is one of my posts for reference with multiple code snippets (also some of the previous posts as well):
The first image has an original size of 26,392 bytes but the file in the post is only 12,304 bytes. That is the fully-zoomed image from here:
https://lavag.org/uploads/monthly_2019_01/591079262_AccessingElementsinaFor-Loop_vi.png.739aeb22d70a5a697b28a8358c333ffb.pngFetching info...
Let me know if I'm doing that wrong
Edited by LogMAN
And referenced in that post is my work around.  It isn't so much that the PNGs are having meta data stripped, it is that they have a custom image viewer which adds a scaling size.  Viewing the raw image still allows snippets.  Also downloading the snippet might work too.
https://forums.ni.com/t5/Feedback-on-NI-Community/How-do-I-get-a-snippet-from-the-board-into-my-block-diagram/m-p/3763571#M15575
So Michael here is a working snippet from NI's site:
https://forums.ni.com/t5/image/serverpage/image-id/214063iB57FB649CBEA2ED8
In this last post of the working snippet. can you explain how you added the image/snippet? I can't seem to reproduce your embed process. When I add an image it adds it and the name changes with an appended hash. it also changes the behavior so when you click it, it pops up in a viewer window. However, with your embed, the image retains its name and clicking it does nothing.
Indeed, the location is different => https://lavag.org/applications/core/interface/file/attachment.php?id=13529
If you go to your profile (icon in the top right) and select "My Attachements", the files listed there show a different file location than the ones in posts. Here is mine from above:
My Attachments
https://lavag.org/applications/core/interface/file/attachment.php?id=13701Unavailable
This one probably works (not tested, just a guess)
Edit: it doesn't.
Post
https://lavag.org/uploads/monthly_2019_01/591079262_AccessingElementsinaFor-Loop_vi.png.739aeb22d70a5a697b28a8358c333ffb.pngUnavailable
Edited by LogMAN
To clarify the second image was posted before the forum update. Here's the thread:
https://lavag.org/topic/20671-programmatically-select-all-boolean-best-way-to-avoid-race-condition/?tab=comments#comment-125949
So, I'm guessing the forum is stripping the metadata on upload now. I reposted that image in this thread by copying the link into the editor box. The box "embedded" the image for me automatically.
