austinman Posted September 2, 2015 Report Posted September 2, 2015 Has anyone tested, or found any information (or heard any rumors) with regard to compatibility of the current LabVIEW FPGA (Xilinx) compilers with Windows 10? I am guessing it is the same issues as with Windows 8 (not compatible), but I thought I would ask Quote
hooovahh Posted September 2, 2015 Report Posted September 2, 2015 At NI Week I asked about this and they said the only compiler supported is the newest ones. I believe they said Vivado. http://digital.ni.com/public.nsf/allkb/02EBA6105D04A1E686257D4E00144C92 That being said if you have an active SSP you don't need to compile your FPGA yourself anymore. NI now includes the free cloud compile for up to 5 simultaneous compilations. https://users.niwsc.com/compilecloud/#/ Quote
smithd Posted September 2, 2015 Report Posted September 2, 2015 The cloud compile is fine unless you need to use IP cores or ip builder. I just tried a Xilinx IP core in win10 with the 9607 target (so it should be using the newest Vivado) and it still doesn't work. 2 Quote
austinman Posted September 2, 2015 Author Report Posted September 2, 2015 My understanding is that the latest version of the Xilinx Vivado compiler is supported by Windows 8 (and I assume 10). I think the problem is NI isn't using the latest Vivado compiler that Xilinx has available. The cloud compile is not an option for my use cases; lack of internet connectivity being a big one. Thanks for the update, smithd. Quote
e_schneider Posted November 23, 2015 Report Posted November 23, 2015 I also have used Win10 in the last 3 months during my current project (LV2014 & without IP Builder). I had no problems generating the bitfiles in the Cloud, but the local compiler got stuck somewhere in the synthesis or mapping. Quote
