Unbundle cluster by order?
  On 12/26/2023 at 7:35 AM, ensegre said:
something along these lines?
Expand
Hi. Thank you for putting this together.
It is not like this actual unbundle but like indexing an array, using the cluster control order to unbundle the item to get it as a control like unbundle by name does.
cheers
M
  On 12/26/2023 at 8:33 PM, Darren said:
What is your use case for needing this behavior?
Expand
Hi Darren,
Well, admittedly, it is my lack of experience with programming.
I wanted to use one wire to carry all my data, so I made an array of clusters, a variant typed and a tag string' to' and did a tag search to find the data and get the variant. To convert that back to my data, I will have to have the original data type feed to "var to data". I want to get this done programmatically. Case structure is a no-go, so I was thinking of bundling all the data, finding the order of the data via the tag, and unbundling that way. Now, I think it was my naivete, and I should not be so lazy and manually do it when I add a new data type.
Cheers
If your cluster contains elements that are all the same data type, you can use the Cluster To Array function.
If your cluster contains elements that are different data types, then the approach you describe won't really work due to LabVIEW's strict data typing.
Expand
Have you considered variant attributes?383584297_VariantAttributesExample.png.b82076ce1d9e6550e7de360fecfeba85.png
In general it is just best to make your cluster a type def (which links all the places that data is used, similar to a defined struct) and then unbundle and bundle the data as needed.  Since LabVIEW is a strictly typed language, getting all data from something like a cluster means it will have to return them as variants.  And then what do you do with that?  Well you'll need the Variant to Data, and specify the type it should turn into.  If it is the wrong type you get an error.  So while you can get all elements of a cluster in an order, the usefulness of it might be limited.  If you are doing something like taking a cluster then writing it to a file, or reading it from a file and you want it to be somewhat human readable, then this might be useful way of doing it.  These functions already exist in the OpenG Variant Configuration File toolkit.
