Bobillier Posted May 15, 2007 Report Posted May 15, 2007 Hi I want to know if and how highlight a cell or a group of cell in a array when you click with mouse on it. (LV7.0 please) I have see that is possible to programmaticaly make selection but not directely with mouse. Eric Quote
lraynal Posted May 15, 2007 Report Posted May 15, 2007 Hi, Here is how you can change the color of the cell you double-click. http://forums.lavag.org/index.php?act=attach&type=post&id=5857 You can work on this example to get what you want ! Good luck, Laurent Here is the code in 7.0 (I hope!) http://forums.lavag.org/index.php?act=attach&type=post&id=5858 Quote
Bobillier Posted May 15, 2007 Author Report Posted May 15, 2007 QUOTE(lraynal @ May 14 2007, 11:44 AM) Quote Here is how you can change the color of the cell you double-click. Thanks But it's for table and not for array. And i whant select element in array of cluster element and this kind of element are not compatible with table, who take only string. Merci tout de même. Eric Quote
lraynal Posted May 15, 2007 Report Posted May 15, 2007 Ok, I see, sorry for the mistake! The only solution I can think of, is to get the Property nodes of all the cells of your table, and then act on them... So, in your Array (in the Front Panel), you right click on each cell, to create a Property node... And after you can change the Text.BGColor of the string. As for the selection of the cell, you can probably re-work my first post, the same way. Hope it will help you! Bonne chance! Laurent Quote
Bobillier Posted May 15, 2007 Author Report Posted May 15, 2007 I have find a solution but a bit complicate. I use a element of my cluster like selection indicator and active it when i do clik on it. Look on my exempl and tell me ifyou see improment fo make it more versatile. A+ Quote
PJM_labview Posted May 15, 2007 Report Posted May 15, 2007 QUOTE(BOBILLIER @ May 14 2007, 06:57 AM) Quote I have find a solution but a bit complicate. I use a element of my cluster like selection indicator and active it when i do clik on it.Look on my exempl and tell me ifyou see improment fo make it more versatile. A+ Look at the attached example from J.P Drolet. I allows element click on to be highlighted (and more). http://forums.lavag.org/index.php?act=attach&type=post&id=5861 Note: To allow the array to show selection, right click on it and select "Advanced>Show Selection" http://forums.lavag.org/index.php?act=attach&type=post&id=5860 PJM Quote
JDave Posted May 15, 2007 Report Posted May 15, 2007 QUOTE(BOBILLIER @ May 14 2007, 06:57 AM) Quote I have find a solution but a bit complicate. I use a element of my cluster like selection indicator and active it when i do clik on it.Look on my exempl and tell me ifyou see improment fo make it more versatile. First, I really like the example code that PJM uploaded. If you need functionality similar to that, you have a great start. If you just want to have a background color indicating the selection, in the past I have had a floating boolean on the front panel. The boolean is behind the array and is the same size as your array element (cluster). The cluster and array background are transparent, so as I move the floating boolean around, it acts to highlight the selected element. This avoids adding another element to your cluster just for GUI purposes. There is some good code in that uploaded example about positioning a floating element to the correct array element location. Better than what I used, actually Quote
Bobillier Posted May 15, 2007 Author Report Posted May 15, 2007 QUOTE(PJM_labview @ May 14 2007, 04:59 PM) Quote Look at the attached example from J.P Drolet. It allows element clicked on to be highlighted (and more). http://forums.lavag.org/index.php?act=attach&type=post&id=5860 Note: To allow the array to show selection, right click on it and select "Advanced>Show Selection" http://forums.lavag.org/index.php?act=attach&type=post&id=5861 PJM Many thanks PJM and J.P Drolet it's exactely wath i looking for. Regards Quote
BrokenArrow Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(dsaunders @ May 14 2007, 12:50 PM) Quote I really like the example code that PJM uploaded. I second that! I never knew that property node existed (the first one on the left that gets the VI's). I would love to have a wall chart of ALL the Propery Nodes available in LabVIEW. It'd be a big one. Laminated. I'd pay money for it. Quote
crelf Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(BrokenArrow @ May 15 2007, 11:34 AM) Quote I would love to have a wall chart of ALL the Propery Nodes available in LabVIEW. It'd be a big one. Laminated. I'd pay money for it. Sounds like the beginning of a beautiful wiki article Actually, I wonder if you could script something like this, and have it autogenerate a BD with a crap-load of property nodes on it and the text from each node's help underneath it... Quote
Jim Kring Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(crelf @ May 14 2007, 06:50 PM) Quote Actually, I wonder if you could script something like this, and have it autogenerate a BD with a crap-load of property nodes on it and the text from each node's help underneath it... Yes, I've heard of such things ;-) Quote
crelf Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(Jim Kring @ May 15 2007, 11:59 AM) Quote Yes, I've heard of such things ...and? Quote
Jim Kring Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(crelf @ May 14 2007, 07:46 PM) Quote ...and? See this thread: http://forums.lavag.org/Dynamic-Generation-of-Labview-82-Class-Hierarchy-t5673.html' target="_blank">Dynamic Generation of Labview 8.2 Class Hierarchy, This is a modified version of PJM's original Quote
Yair Posted May 16, 2007 Report Posted May 16, 2007 QUOTE(Jim Kring @ May 15 2007, 07:07 AM) Quote See this thread:http://forums.lavag.org/Dynamic-Generation-of-Labview-82-Class-Hierarchy-t5673.html' target="_blank">Dynamic Generation of Labview 8.2 Class Hierarchy, This is a modified version of PJM's original And now the trick would be using the picture control to generate a nice diagram of them so it could be printed. Quote
Bobillier Posted May 18, 2007 Author Report Posted May 18, 2007 I have creat one another exempl more simple using the clickedarrelement.vi of jp Drolet. In my exempl you can too make multi selection.Perhapse it can be see as an up grade of Jp Dolet Vi. Quote
hooovahh Posted February 7, 2014 Report Posted February 7, 2014 On 5/15/2007 at 11:05 AM, lraynal said: Hi,Here is how you can change the color of the cell you double-click. http://forums.lavag.org/index.php?act=attach&type=post&id=5857 You can work on this example to get what you want ! Good luck, Laurent Here is the code in 7.0 (I hope!) http://forums.lavag.org/index.php?act=attach&type=post&id=5858 A user complained that these links are dead. I don't have the original VI but I implemented some code that is similar in functionality. You click cells in a Table, or Multicolumn Listbox and the color changes. There is also a Clear Color button that changes all cells back to white. Saved in 2011. This cannot be done with an array control because the only thing that can be different between elements of an array is the value. If you try to set the background color it will set it for all elements in the array not just the one cell. Color Cells Mouse Click.viFetching info... Quote
