CunZhang Posted September 18 Report Posted September 18 This toolkit offer you an efficient, stable, and reliable front panel control value refresh function. User can design their UI dashboard without any code development. 1. Powerful parallel execution capability, Support clone reentrant execution running mode, you can create multi dashboard UIs at the same time and controls can synchronous refresh across different UI. 2. High-speed data refresh capability, even with thousands of controls on a single UI, can easily maintain a refresh rate of 50ms while consuming very little CPU resources. 3. Support all control data types that "Tag Engine" support, this mean the only thing you need to do is to change the control "Label" with "Tag name", then the control will refresh automatically. 4. Support "muParser Expression", you can type the control "Label" with "Expression" that muParser Expression support, For example "a + b" "a > 1 & b >= 2". 1 Quote
Rolf Kalbermatter Posted September 19 Report Posted September 19 You may also want tell people where you can actually download or at least buy this. Although if you want to sell it, do not expect to many reactions. It is already hard to get people to use such toolkits when you offer them for free download. 1 Quote
CunZhang Posted September 20 Author Report Posted September 20 17 hours ago, Rolf Kalbermatter said: You may also want tell people where you can actually download or at least buy this. Although if you want to sell it, do not expect to many reactions. It is already hard to get people to use such toolkits when you offer them for free download. Good suggestion, But so much documentation need to prepare, I'm trying my best. Will post the download link here if everything done. Quote
tylerwindy Posted 1 hour ago Report Posted 1 hour ago 我非常的期待,并且如果需要的话我愿意一起去完善,我正在为大量Ui控件的快速刷新感到苦恼 Quote
