Design their UI dashboard without any extra code for control values refresh
This toolkit offer you an efficient, stable, and reliable front panel control value refresh function. User can design their UI dashboard without any code development.
1. Powerful parallel execution capability, Support clone reentrant execution running mode, you can create multi dashboard UIs at the same time and controls can synchronous refresh across different UI.
2.  High-speed data refresh capability, even with thousands of controls on a single UI, can easily maintain a refresh rate of 50ms while consuming very little CPU resources.
3. Support all control data types that "Tag Engine" support, this mean the only thing you need to do is to change the control "Label" with "Tag name", then the control will refresh automatically.
4. Support "muParser Expression", you can type the control "Label" with "Expression" that muParser Expression support, For example "a + b" "a > 1 & b >= 2".
You may also want tell people where you can actually download or at least buy this. Although if you want to sell it, do not expect to many reactions. It is already hard to get people to use such toolkits when you offer them for free download.
  • Thanks 1
Good suggestion, But so much documentation need to prepare, I'm trying my best. Will post the download link here if everything done.
Very neat looking. I like the concept. I do think people might not like the unprotected nature of being able to read and write to tags from anywhere.  Imagine I have a sensor that keeps flipping back to NaN.  I suspect trouble shooting where the tag is getting written from, or debugging this type of wireless program can be a challenge. If tools are made for tracking this type of thing it might make it easier.
This also would make something like dynamic UIs easier.  You can have a set of controls that can be inserted into subpanels, and then to read/write data you just need the controls named something specific.  Oh that gets me thinking, can the tag be based on the Caption of the control not the label?  That way it can change at runtime.
Also I think the video should have been a youtube link. Watching such a long gif is a weird experience without pause, or playback controls.
Good idea, here are vidio links, and this toolkit will be uploaded to VIPM soon.
YouTube video: https://www.youtube.com/watch?v=18rNEuNJJks
Bilibili video: https://www.bilibili.com/video/BV1EexEzAEW
PS: I had add a enum to choose "Label" or "Caption"
On 9/30/2025 at 4:02 PM, tylerwindy said:
我非常的期待,并且如果需要的话我愿意一起去完善,我正在为大量Ui控件的快速刷新感到苦恼
感谢你的关注,我正在准备将这个工具上传到VIPM上,不久将可以下载使用。
