Hardware necessary for project
Bulletman
Dear All,
My name is Dennis aka "bulletman". I'm a chemical engineer and at this moment
I have an experimental setup that I would like to control with Labview. At this moment
everything is done manually. The setup contains the following things:
3x Balances RS232
6x Mass Flow Controller, RS232
1x Mass Flow Reader, RS232
3x Temperature Control, RS232
2x ISCO pumps, RS232
2x Characterization machines, RS232
One week ago, I started to be interested in using labview and I did some online tutorials and played around in the programm itself.
I think the program itself is not that hard to use, but I don't have any experiences with data acquisition so far. At this moment I'm not
sure which kind of hardware I need for my purpose. If I understand correctly, I need a DAQ card which is connected to a box with multiple
RS232 connections. By addressing the cards com port and the respective channel (every channel is anothere RS232 port?) it becomes possible
to read/control the experiment? Please help me out!
Next, Do you guys think it is duable (for an in-experienced person like me) to write a labview program that is able to control/read the MFC's, TC's, pumps etc.
Thanks,
Dennis
Hi Dennis,
it's totally doable. It's in fact much easier than you think it could be. Installing a card to multiplex your RS-232 ports will give you as many COM ports you need. Use Measurement Automation Explorer to configure them and use Instrument I/O Assistant to get started. (Instrument I/O palette)
QUOTE (jgcode @ Nov 25 2008, 08:34 AM)
Which ever hardware platform you choose, from your current spec you will need at least serial 17 ports.
Or daisy-chaining the equipments if some are compatible with this control method.
I've got an even easier and ultimately cheaper way - use a "serial concentrator". They're dedicated cards that have many many ports on them, and are specifically made for what you want. They just show up as ports in MAX, and you access them in LabVIEW.
The only limitation with them is that they're expensive, but you're in luck! I have a bunch of them in my prototype lab left over from a recent project (we used 128 ports simultaneously with no issues at all), they're brand new in the box, that I can let you have for a very low price (we're not using them, so I'd prefer to see someone get some value out of them rather than just taking up room in our lab). Let me know if you're interested.
We have one application where we are using 12 USB to RS232 dongles + the one on board RS232 port with no issues. You can pick the adapter dongles up for less than $15 each so that might be an option as well. The only thing we had to do is to force each adapter to a specific com port so that if it got plugged into a different USB location it would keep the same COM port number.
QUOTE (crelf @ Nov 25 2008, 10:12 AM)
QUOTE (TobyD @ Nov 25 2008, 11:05 AM)
I was going to suggest RS232 to RS485 converters to make one network, but I like some of these solutions better.
Tim
Thank you for all your answer. I'm going to look into all your solution. I'm unfamiliar with most of the termination that you use and therefore it might take a while before I understand all options! Thanks for all your help!
@Ton: Don't worry....a chemical engineer addicted to the cheap energy drink "Bullit".....but bulletman sounds better ;)
