crossrulz
Members
  • Posts
    553
  • Joined
  • Last visited
  • Days Won
    28
crossrulz last won the day on June 30
crossrulz had the most liked content!
1 Follower
Profile Information
  • Gender
    Male
  • Location
    Cincinnati, OH
LabVIEW Information
  • Version
    LabVIEW 2019
  • Since
    2005
Recent Profile Visitors
The recent visitors block is disabled and is not being shown to other users.
crossrulz's Achievements
  1. You should replace the Type Cast with a String To Byte Array. It turns the type cast into a NoOp under the hood and is just a lot easier to read. I also highly recommend you turn on the Display Style for all of your string controls and indicators (Right-Click->Visible Items->Display Style). This is a way of making sure you know how your data is encoded and eliminate a lot of confusion. CT003 CRC checksum.vi
  2. I've generally been recommending using at least 2025 because the project dependency list is no longer saved in the project file (it got recalculated at loading anyways), making GIT commits cleaner. And the in-place save for previous (introduced with 2024) is really nice to have. I have been using 2026Q1 for my development, including a major refactoring of my HAL architecture. I've had very few issues, almost all of which were fixed by clearing the object compile cache regularly (something I have a habit of doing anyways since at least 2016). And just to throw it out there, we are expecting 2026Q3 to drop any day now. No promises from NI on a date, but we are in Q3 now.
  3. If you have a specific structure for your chambers (ie everybody is under the "Hooovahh Chamber" directory), you could do a simple lookup and use the Get LV Class Default Value to dynamically load the classes. I do something similar with my HAL already, except I dictate what class to load based on a JSON file.
  4. My part of the world! Unfortunately, I don't have any connections to the realm you are talking about. But I would look at Northern Kentucky University (just across the Ohio river) as they have a good CS program (or at least used to). There is also Miami University (not to be confused with the one in Florida), Wright State University (where I got my MSE), and University of Dayton about an hour north of here in the Dayton area. University of Kentucky is about 2 hours south (Lexington, Kentucky), which is about the same distance from Ohio University (Athens) or THE Ohio State University (Columbus).
  5. Yes, decoupling is a long process. I have been trying to do that with the Icon Editor. Not trying right now as other priorities with that project are more important. Do the process slowly and make deliberate efforts. You will eventually see the benefits.
  6. I recently created a VIPC file with an unregistered free edition. I too thought it was a pro feature until I went to try to make one for the Icon Editor.
  7. There is an Application property called Display->All Monitors. It will give you the pixel ranges of the monitors in your system. What I've done is to use the calling VI's position to figure out which monitor it was on and then place the new VI window as needed. You could use a win32 dll call to get the mouse position as well if that better meets your requirements.
  8. If you look at the actual array sizes, things will make a lot more sense. 1. The Build Array will add the number of expanded elements to the first dimension. The array size after the first Build Array is (2,0), which is still an empty array. 2. The Transpose Array will swap the array sizes. The array size after the Transpose Array is (0,2), which is still an empty array. 3. Again, the Build Array will add the number of expanded elements to the first dimension. In this case, it will add 1 to the first dimension, resulting in the array size being (1,2), which is no longer an empty array.
  9. To be honest, I always thought those should be in the Visible Items menu.
  10. Another part of this history: JKI forced NI's hand to release scripting (officially supported and open for everybody to use) with their Right-Click Framework. This is how I discovered scripting. I think I even wrote one or two plugins for myself. Then something happened in LabVIEW 2011 or 2012 that broke it. I asked Michael Aivalotis about it and that's how I found out this part of the story. JKI had no intention of fixing the issue because their mission was accomplished.
  11. What exactly are you referring to when you say "library"? A dll? A LabVIEW library (which is sort of a container for code)? A third-party package of code?
  12. I just noticed the LabVIEW Wiki YouTube account is now gone. What has happened to the videos that were there? My VIWeek presentation (Proper Serial Communications) was one of those handled by this account.
  13. Is ShaunR actually a robot? https://www.youtube.com/watch?v=UymlSE7ax1o
  14. I have had this in my toolbox for a long time to do what you are asking. It is part of a QuickDrop plugin I made to "fix up" a VI, similar to Darren's Nattify plugin. Size Diagram Window.vi
  15. Hopefully, these are just those sleeper accounts Michael mentioned earlier.
