Display images from a folder
I am looking to display images from an image folder containing mostly jpg images. I want to be able to display the images on the front panel and cycle through them through a button. How would I do this? This is what I have so far I just want to be able to cycle through the images by means of a button.
LabVIEW 2013
post-51482-0-31982500-1397216866_thumb.p
Edited by PauldePaor
Your image doesn't look like it represents the function you are asking for.  I implemented the function the way you described it.  You provide a folder of JPGs and run.  It loads the first picture in the folder.  If there isn't any it prompts you.  Once it has been loaded you use the Next and Previous buttons to go between images.
Cycle Through Images.vi
