Tom Fantasia Posted August 13, 2014 Report Posted August 13, 2014 I am accessing a TDMS file from two VIs running in parallel. One VI is responsible for opening the TDMS file and writing a property. The second VI is responsible for reading said property. Here's where things get interesting...The second VI cannot find the property while the first VI has the TDMS file open unless the first VI also writes data to the TDMS file. I've created a few VIs (attached) to help illustrate the problem. Any ideas as to what is going on? I would have expected properties to be available as soon as they are written. Read TDMS Property Names.viFetching info... Write TDMS Property (with data).viFetching info... Write TDMS Property.viFetching info... Quote
hooovahh Posted August 14, 2014 Report Posted August 14, 2014 Okay here's the issue or what I believe is the issue. TDMS may not write to disk immediately after a write or set properties. Because of this opening a second reference to a file is really a race condition between the flush routine and the read. The way to fix this is to only perform the TDMS open in one location, and then share that reference to the read, and write operations. Don't open a second reference to the file. Quote
Tom Fantasia Posted August 15, 2014 Author Report Posted August 15, 2014 Sharing a single reference would solve this particular problem. It would also add more messaging overhead. The process that closes the reference would have to notify the other processes and wait for acknowledges before it could safely close the reference. Otherwise another process could attempt to access the TDMS file with a bad reference. One of the reasons I chose to use the TDMS file format was its out-of-the box support for concurrent access. Perhaps properties writes don't work the same way as data writes do (as you hypothesize hooovahh)... Quote
JKSH Posted August 15, 2014 Report Posted August 15, 2014 Hi Tom, Does it help if you call TDMS Flush.vi after you write the property? On 8/15/2014 at 1:36 AM, Tom Fantasia said: Sharing a single reference would solve this particular problem. It would also add more messaging overhead. The process that closes the reference would have to notify the other processes and wait for acknowledges before it could safely close the reference. Otherwise another process could attempt to access the TDMS file with a bad reference. To avoid race conditions, you'd need some form of messaging/synchronization anyway: You need to ensure that your Read VI waits for your Write VI to finish writing the property first, before it tries to read it. Quote
hooovahh Posted August 15, 2014 Report Posted August 15, 2014 Yeah I assume flush would fix this, but cause the index file to be larger than it could be. I handle this by only having the open in one place and reading and writing all comes from that one actor, with messaging to other actors if they want to write, or read data. I understand the concurrent references idea and that is an appealing feature, but race conditions like this can happen and sometimes that doesn't matter, but it sounds like in this case it does. 1 Quote
Tom Fantasia Posted August 19, 2014 Author Report Posted August 19, 2014 NI's support team determined that this issue is a "potential bug." Follow CAR 488186 for updates. Quote
drjdpowell Posted August 20, 2014 Report Posted August 20, 2014 On 8/15/2014 at 1:36 AM, Tom Fantasia said: Sharing a single reference would solve this particular problem. It would also add more messaging overhead. The process that closes the reference would have to notify the other processes and wait for acknowledges before it could safely close the reference. Otherwise another process could attempt to access the TDMS file with a bad reference. One of the reasons I chose to use the TDMS file format was its out-of-the box support for concurrent access. Perhaps properties writes don't work the same way as data writes do (as you hypothesize hooovahh)... You could solve this with custom Open and Close VIs that maintain a single TDMS reference, and a running count of the number of processes that have called “Openâ€. Count up for Open and down for Closed, closing the file when the count gets to zero. One could also use a named single-element queue to hold the file, as named queues have similar “count-the-number-of-opens†properties. Quote
