Sparkette Posted August 22, 2015 Report Share Posted August 22, 2015 I have a challenge for you: looking at this VI snippet, it appears that this loop should stop after 11 iterations. However, when you click Run Once, it doesn't stop. See if you can figure out why it doesn't stop. Hint (if it really is much of a hint): it uses a trick I sincerely doubt you've ever seen before! If you don't have LabVIEW 2015 (or don't feel like loading it from a VI snippet), here's a version that should work on versions as far back as 2009: LV2009.vi Link to comment
JKSH Posted August 22, 2015 Report Share Posted August 22, 2015 :-S What did you DO to the subtract node?! 1 Link to comment
ShaunR Posted August 22, 2015 Report Share Posted August 22, 2015 (edited) + and - primitives use the compound arithmetic node, IIRC. I expect you set the first terminal to invert? What do we win if we get it right? Edited August 22, 2015 by ShaunR Link to comment
Sparkette Posted August 22, 2015 Author Report Share Posted August 22, 2015 (edited) + and - primitives use the compound arithmetic node, IIRC. I expect you set the first terminal to invert? What do we win if we get it right? It's clearly not a compound arithmetic node. Is there a way to make one look like a regular subtract node or something? And you don't win anything; I'm just curious if anyone will figure it out. Edited August 22, 2015 by flarn2006 Link to comment
drjdpowell Posted August 22, 2015 Report Share Posted August 22, 2015 Did you wire up the minus as 2-(shift reg), then move the wires around to make it look like (shift reg)-2? Then the shift reg would go 10, -8, 10, -8,… and never be less than -10. 1 Link to comment
pawhan11 Posted August 22, 2015 Report Share Posted August 22, 2015 Replaced subtract node and now works as it should Why I have no idea ... Link to comment
LogMAN Posted August 22, 2015 Report Share Posted August 22, 2015 Did you wire up the minus as 2-(shift reg), then move the wires around to make it look like (shift reg)-2? Then the shift reg would go 10, -8, 10, -8,… and never be less than -10. I guess you are right, however the wires are not wired around, the Subtract function is actually flipped horizontally : I'm still trying to figgure out how you did that, flarn2006... Please tell me if it is not possible from within LabVIEW or I die before solving this Link to comment
JKSH Posted August 22, 2015 Report Share Posted August 22, 2015 I'm guessing h I guess you are right, however the wires are not wired around, the Subtract function is actually flipped horizontally : Flipping Magic.png I'm still trying to figgure out how you did that, flarn2006... Please tell me if it is not possible from within LabVIEW or I die before solving this I'm guessing he used his backdoor VI editor (https://lavag.org/topic/19178-low-level-vi-data-editor-warning-not-for-production-use/) to create a mutant subtract node 2 Link to comment
JackDunaway Posted August 22, 2015 Report Share Posted August 22, 2015 dcoFiller=0x2 apparently swaps mapping of parameters to instruction, and also prevents the top wire from becoming a stomper. 0/10, would not recommend; stick to dcoFiller=0x3 1 Link to comment
LogMAN Posted August 22, 2015 Report Share Posted August 22, 2015 (edited) I'm guessing he used his backdoor VI editor (https://lavag.org/topic/19178-low-level-vi-data-editor-warning-not-for-production-use/) to create a mutant subtract node That is cheating! ... But I guess you are right. dcoFiller=0x2 apparently swaps mapping of parameters to instruction, and also prevents the top wire from becoming a stomper. 0/10, would not recommend; stick to dcoFiller=0x3 Hehehe... Found a new toy to trouble our trainees with. Edited August 22, 2015 by LogMAN Link to comment
Sparkette Posted August 22, 2015 Author Report Share Posted August 22, 2015 I'm guessing h I'm guessing he used his backdoor VI editor (https://lavag.org/topic/19178-low-level-vi-data-editor-warning-not-for-production-use/) to create a mutant subtract nod Correct! More specifically, I switched the "bounds" properties of the two input terminals. Link to comment
JKSH Posted August 22, 2015 Report Share Posted August 22, 2015 Correct! More specifically, I switched the "bounds" properties of the two input terminals. Please ensure that your genetically-modified nodes don't escape into the wild! Link to comment
Sparkette Posted August 23, 2015 Author Report Share Posted August 23, 2015 (edited) Please ensure that your genetically-modified nodes don't escape into the wild! Don't worry; the default palette is 100% organic. Edited August 23, 2015 by flarn2006 Link to comment
X___ Posted January 28, 2022 Report Share Posted January 28, 2022 Replacing the Subtract operator by the Compound Arithmetic one fixes the sickness. Link to comment
Please sign in to comment
Sign In Now
