Tab showing after open, but prior to run
So I have a multi-tab GUI. But for some reason, on load before run, it doesn't display the tab that was showing on save. It shows a tab which I don't want to be showing instead. On run, it starts with the right tab. Then saving and closing with that tab showing, on re-open (before run) it still shows a tab I don't want. How can I influence that?
On top is the tab I want to show on open before run. At bottom is the tab that shows instead. You see my problem...
Edited by Gan Uesli Starling
clarification
It sounds like you have made the 'Service Use Only' tab the default value for the Tab control. Select the 'Manual Adjust' tab, right click on the tab, and from the short-cut menu select Data Operations>>Make Current Value Default.
