GregFreeman Posted September 21, 2017 Report Share Posted September 21, 2017 I have been getting some hard crashes in my built application and I have some strange feeling (although it's just a guess) that it is related to a combination of using the database toolkit in a pool of workers that are launched by the start async call node. Their job is to sit there and monitor a directory then parse data files and throw their contents at the database through a stored procedure call. All my hardware comms (2 instruments) are using scpi commands through VISA GPIB and TCP so I think the risk that those are causing crashes is relatively low. Active X inside a bunch of parallel threads seems far more risky, even though as far as I can tell adodb should be thread safe, and each thread manages its own, unshared connection. These crashes are happening ~once a day on multiple test stations. I have sent the crash dumps to NI but am waiting to hear back. Right now I am grasping at straws because when I look at the dump file it's pointing me to function calls in the lvrt dll which does nothing for me. I am mostly just looking for any debugging suggestions or direction to getting this resolved more efficiently than just disabling code one loop at a time. I'm also curious if anyone has seen something similar. For the time being, I have reduced my number of workers to 1 in case it is a thread safety issue. I have also considered getting rid of that DB toolkit and leveraging .NET, even though I think that is just a wrapper around the same calls. Looking inside the database toolkit VIs alone scares me. FWIW I am using LabVIEW 2013 in this application. Thanks! Quote Link to comment
bbean Posted September 21, 2017 Report Share Posted September 21, 2017 what kind of hardware is the application running on ? eg desktops, rackmount computers, pxi racks? Quote Link to comment
GregFreeman Posted September 22, 2017 Author Report Share Posted September 22, 2017 (edited) Desktop, windows 7. Connected to Oracle 12c database. Edited September 22, 2017 by GregFreeman Quote Link to comment
bbean Posted September 22, 2017 Report Share Posted September 22, 2017 Ok if you said PXI I was going to say check the RAM type. I had a evil crash that appeared randomly on machines and after a long process with NI's help found that it was the RAM. NI sells "certified" RAM for the their PXI's and I will always buy that in the future even though its a complete ripoff. Back to your issue. Have you tried the Desktop Execution Trace Toolkit to check for reference/memory leaks yet? I wouldn't be scared about going under the hood of the db toolkit, but I wouldn't go there quite yet. Quote Link to comment
drjdpowell Posted September 22, 2017 Report Share Posted September 22, 2017 (edited) It’s not likely to be related to the Async Calls, per se, as those don’t have anything to do with threads (async-called VIs run on the same threads as all other subVI calls). Edited September 22, 2017 by drjdpowell Quote Link to comment
GregFreeman Posted September 25, 2017 Author Report Share Posted September 25, 2017 On 9/22/2017 at 6:03 AM, bbean said: Back to your issue. Have you tried the Desktop Execution Trace Toolkit to check for reference/memory leaks yet? Nope, but that is a good idea. Working on getting that set up now. Don't know if it makes a difference but here is the output from the bottom of the lvlog.txt file. <DEBUG_OUTPUT> 9/23/2017 4:20:51.818 AM Crash 0x00000000: Crash caught by NIER File Unknown(0) : Crash 0x00000000: Crash caught by NIER minidump id: 41eb3397-b106-4d85-a433-2ce31d619f06 ExceptionCode: 0xC0000005 </DEBUG_OUTPUT> 0x30762E76 - lvrt <unknown> + 0 0x30763518 - lvrt <unknown> + 0 0x30079A96 - lvrt <unknown> + 0 0x307F05C1 - lvrt <unknown> + 0 0x308035CD - lvrt <unknown> + 0 0x768F62FA - USER32 <unknown> + 0 0x768F6D3A - USER32 <unknown> + 0 0x768F77C4 - USER32 <unknown> + 0 0x768F788A - USER32 <unknown> + 0 0x3088BDBD - lvrt <unknown> + 0 0x3088C237 - lvrt <unknown> + 0 0x01471B06 - QtManager452_2013 <unknown> + 0 0x670E7251 - NIQtCore_2013 <unknown> + 0 0x00000000 - <unknown> <unknown> + 0 0x00000000 - <unknown> <unknown> + 0 Quote Link to comment
