How to make SUBVI change Mouse Icon programmatically
Good Evening
I'm new in LabVIEW, please be patient with me :)
I was working in a User Interface for my application. My plan is to use a main.vi file and load a subvi in each of the four splitters.
But there are two problems that I cannnot solve:
1) I want transform the part of the code that change the mouse icon into a subvi. But the option Edit > Create SubVI isn't working well because of the boolean value change in the Event Structure
2) When I load a subvi into a sub panel, I want the "mouse icon change" code work inside the subvi. How can I do that without copying the code into the subvi?
Edited by mthheitor
  • 1 month later...
Thanks @ShaunR, the "Inserted VI" Property is available in LabVIEW 2012. Worked perfectly.
Please, can you explain me why we had to change the Property: Owning VI (Property Node) from my old code inside the case structure "Mouse Enter" and "Mouse Leave" to a VI Server Reference (your new code).
It's about the refnum, right? But couldn't understand that very well.
The Property Node "Owning VI" gets the refnum from the subvi, but we needed the refnum from the main.vi?
