Any reccomendation for tools to get started with OOP?
Hey all,
I want to start my first big design in LV with OOP by laying out and designing a motor class.  I was wondering if there are any tools that I should look into to help me with the process.  I've built a power supply class which is basically an abstract factory where all the children create the concrete classes. I am still trying to understand a lot of the different architectures/design patterns from the LV forums but am getting a better understanding each time I go through them again.  My biggest issue I can see is having child classes return different data types without it getting overly complicated (any suggestions on designs on this front are more than welcome).
Digressing back to the original question, As of right now I am looking into GOOP, but its occasionally crashing LV 2015.  It seems like theres some good stuff with GOOP, but the lack of documentation is a bit rough to slog through.  I was wondering if you fine folks could recommend any tools for me to look into as well.
I'm sorry this is a generic request, but I don't know what I don't know.
Matt
Factory is a good way to create your instruments but you probably want one factory for all instruments rather than one for each type. That way you only pass the parent (abstract) reference around, which makes it easy to swap out one concrete instrument for another of the same type. Returning different data types from classes of the same instrument type is something you don't want. When designing your classes, you should already know what kind of data you expect that class structure to handle and all instruments of one type should be able to put their data into that one given format.
Maybe @MikaelH can throw the Introduction to OpenGDS pdf your way. I can't find it.
You need see past your specific motor types to think what your generic motor needs to do.  Is it returning configuration info?  That can be JSON, rather than a typed cluster.  Or a Variant, or an object of a "config" subclass.
My advice is to NOT learn OOP with a Motor Parent class unless you have enough experience with different motor types so that you can form a solid view of what a generic motor does.
@MikaelH Thanks for the links good sir, I appreciate it!
@ThomasGutzler What do you mean by "Returning different data types from classes of the same instrument type is something you don't want."?  I'm assuming you mean something like use the parent "Power Supply" object for my connector panes and define the child (such as TDK Lambda) during the initialization section of my test.  This way the if I wanted to change the PS from TDK Lambda to say Sorenson, all I'd have to do is change the test's initialization section since all my connector panes are using the Power Supply parent class in their connector pane.  If this is the case, I am doing that already, I may just be bad with my vocabulary.
@drjdpowell Fair point, learning to walk makes running a lot easier.  I guess what I am currently trying to do is define my end goal and figure out the different steps along the way.  Then start working on the individual steps to build up to my end goal.  Like for a generic motor (in my case) I'll need a power supply class and CAN communication class as my main two classes along with some other private methods/data (ignition task and methods, motor info, stuff like that).  As far as the CAN coms, I am actually running into a bit of an issue trying to figure out how exactly I want to lay it out.  I'm using XNET and I'm trying to figure out how I should handle having things like single point signal/frame as well as queued signal/frame.  If I go down the splitting out all of those into their own child class, then I'm going to have 4 child classes for my basic XNET write class.  OR I could try and go into a strategy pattern where the XNET class has some other class information that contains how the data is supposed to be written (something like the CookingStrategyPattern from here.)
Thanks all for responding, I appreciate the help!
I think what Thomas meant is that if you are going to use Dynamic Dispatch (DD) then you are forced to have the same data type as the connector pane of the concrete DD VIs all have to be identical. If you already have something working its probably ok. As an example you cannot have Instrument 1 return an array of DBL and Instrument 2 return an array of SGL for a "Read.vi".
Edited by Neil Pate
What Neil said. Looks like you've got it worked out.
The hardest thing to get your head around is the factory instrument creation. This is the only place where you might not use dynamic dispatch to call instrument specific vis containing their specific configuration. But as @drjdpowell said, you can use JSON for that.
Just be really careful if you intend to used packed libraries. Start building the exe & ppls now. It is not trivial. It's of limited use if it can't be deployed.
This is the best documentation I've found yet.
Effectively_Using_Packed_Project_Libraries_SEPAD.pdf ‏2772 KB
https://forums.ni.com/t5/NIWeek-Session-Content/Software-Engineering-Processes-Architecture-and-Design-nbsp/ta-p/3929895?profile.language=en
  • 5 weeks later...
This is where my hiccup is, I am using the factory template for my power supply class since I know what my outputs and inputs are.  I can use the DD to set/read my voltage, current, or output state since I know they will be double, double, and boolean respectively.  I was thinking about using the factory pattern for an XNET Read class, but there are 3 basic methods to read from XNET - signal, frame, and XY.  Theoretically, i could force all of these into an XY format.  I am trying to figure out how I can use something like a dynamic dispatch to read anything from XNET without having to create 3 specific XNET read subclasses to an XNET read class.  And then taking that further, what about a generic read class where I could read DAQmx data as well as XNET data?
My current thought is so have a "Read" and "Read Type" class used to build my XNET read.  Read would be an abstract class containing queues and events so my Read Type Class knows where to send the data.  Read Type would be another class that would implement how I want to read this specific type of class.  For example, Read Tye could be XNET signal/frame/XY or DAQmx Analog/digital/counter since the read type class is my strategy of how I want to read my data.
Sounds... Complicated.
I honestly think OOP designs like this are generally more trouble than the return you get from it.
You use some patterns in the wrong context.
The Factory pattern is only a means to create new objects without explicitly referencing them. Here is a very simple example using a Boolean to select from two classes.
In this example, Class 1 and Class 2 both are children of Superclass. Depending on the input value, one of them will be returned. The caller doesn't need to know how to create those objects and only sets the input value to True or False. A typical implementation uses a String instead of a Boolean, which allows for many more options and adding more classes later.
In any case, the output of a Factory is the most common ancestor of all possible children (Superclass in this example).
Dynamic dispatching is not something that magically merges different functions into one. It is only a way to change the behavior of a function at runtime.
Perhaps you are familiar with Polymorphic VIs. Dynamic dispatching is actually very similar to polymorphism. The difference is how they are resolved. Polymorphic VIs are resolved at edit time. Dynamic dispatch VIs on the other hand are resolved at runtime. This is why dynamic dispatch VIs must always have the same terminal pattern. This is of course a very simplified explanation.
For your particular question, there are two parts to it:
  • Create specific subclasses for each type of power supply - For example, XNET and DAQmx are entirely different technologies, so it makes sense to have separate classes for each.
  • Use the Strategy Pattern to change the behavior of a particular method - For example, your XNET class could use different strategies to do the actual read operation (XY, double, etc.).
The Strategy Pattern encapsulates an operation in an object. You need to write one object for every possible strategy and then provide the desired strategy at runtime (i.e. using a Factory). Here is a basic example.
In this example, XNET is a subclass of Power Supply, which has a Read Data method that returns an array of double. When XNET is created, the desired read strategy is passed as an argument. The strategy has another dynamic dispatch method to do the actual read operation. The Read Data method then uses the strategy to read the data. DAQmx would work similarly, perhaps with its own set of strategies.
I believe that this comes very close to what you have in mind.
Don't put events and queues inside the reader class. Instead, have a separate class that uses the reader class to produce events or populate queues (these should be separate classes altogether, one for queues and one for events).
I suggest you play around with the different patterns to get used to them before you use them in production. OOP can get confusing very quickly if you are only used to functional programming.
Agreed completely.  I understand that DD is basically allowing the child to redefine a method via overwrite or extend it via overwrite w/ calling the parent's method.  Because of this, as you said, all the connector panes for the DD VI must be the exact same.  So, if I want to be able to read multiple types of data from a class, DD won't work for a genera "read", hence my question.
You are correct, this is basically what I am thinking.  I think having a separate read type class that implements how the data is read, or its strategy, is how I can get around multiple read types.  From there I was thinking about sending the data via queue to a different "display class".  This way, the read type class can have a DD VI called read, where it calls the child class read function (XNET signal/frame/XY) and send it to the display via queue.  The queue control will most likely be a variant and enum, variant being the data read from read type and enum being the read type it came from (I've seen that I'm not supposed to send classes via queues so this is my work around to properly cast my variant to the correct data).
When I was talking about events/queues, I mean more like a queue to send my data (not read) or an event struct with a 0ms timeout to monitor if a stop condition occurred.  I understand I don't want to induce additional delays in my read to avoid timeouts.
Not sure where you got that. It's a valid approach: Command pattern - LabVIEW Wiki
The Actor Framework, for example, takes this idea to the extreme.
I'm not a fan of the 0ms timeout case because it adds unnecessary polling. The rest sounds good to me. It is probably best if you build a prototype to see what works best for you.
