Antoine Chalons Posted April 8, 2021 Author Report Posted April 8, 2021 Oh, and by the way, the VIP is now available on vipm.io : https://www.vipm.io/package/lv_toml/ 1 Quote
bjustice Posted April 8, 2021 Report Posted April 8, 2021 (edited) Correct. Ahh, I typically only read the files. But yeah, the writer portion of the code doesn't in-place edit a file, so yeah, the comments would be lost. Good point. I'm not sure of the way around this. How is JDP handling this? I assume that he's going to have the same issue with JSONtext (since he added comments in the latest JSONtext release) Edited April 8, 2021 by bjustice Quote
Antoine Chalons Posted April 8, 2021 Author Report Posted April 8, 2021 I haven't checked how he handled comments. I started thinking about variant attributes to handle them (text and position) but it quickly gets tricky so for now I've accepted to either only read or lose comments. Quote
drjdpowell Posted April 8, 2021 Report Posted April 8, 2021 (edited) There are actually multiple different use cases of config files, and multiple ways to implement those uses cases. My most common use case is "Computer writes config; Human reads and may modify; Computer reads config". The way I do this is mostly: Read config file into Application data structures. Later, convert Application data structures into config file. Comments don't exist in the Application data structures, so comments get dropped. Another (used, by the NI/OpenG INI libraries, and I'm guessing your TOML stuff) is: Read config file into intermediate structure Query structure to set Application data structures Update intermediate structure with changed values from Application data convert intermediate structure back to a config file Here, the intermediate structure can remember the comments in the initial file and thus preserve them. But, IMO, this is also less clean and more complex than the first method, as you have an additional thing to carry around, and the potential to forget to do that "update" part. Currently, with the latest version of JSONtext (now available!), I haven't really developed this second, comment-preserving method. I am more thinking of another, less common but important, use case: "Human writes (possibly from a template); Computer reads", where the computer never writes (this is @bjustice use case, I think). Here, the human writes comments (or the Template can be extensively commented). But I do intend to support keeping comments. It will probably involve applying changes from the new JSON into the original config-file JSON, preserving comments (and other formatting). But that is for the future. Note added later: the config-file JSON with Comments is now available in JSONtext 1.6.5. See https://forums.ni.com/t5/JDP-Science-Tools/BETA-version-of-JSONtext-1-6/m-p/4146235#M39 Edited January 28, 2022 by drjdpowell Quote
drjdpowell Posted April 8, 2021 Report Posted April 8, 2021 48 minutes ago, Antoine Chalons said: I started thinking about variant attributes to handle them (text and position) but it quickly gets tricky so for now I've accepted to either only read or lose comments. I think you just need an extra string for each item to hold end-of-line comments, plus a "no item" data type to allow full-line comments. See how teh NI INI Library does it. Quote
drjdpowell Posted April 8, 2021 Report Posted April 8, 2021 BTW, one other use case I've had is "Multiple applications read/write to common config file", which requires careful thinking about preventing one App from overriding changes made by another App. 1 Quote
ShaunR Posted April 8, 2021 Report Posted April 8, 2021 1 hour ago, drjdpowell said: My most common use case is "Computer writes config; Human reads and may modify; Computer reads config". The way I do this is mostly: Read config file into Application data structures. Later, convert Application data structures into config file. Comments don't exist in the Application data structures, so comments get dropped. Another (used, by the NI/OpenG INI libraries, and I'm guessing your TOML stuff) is: Read config file into intermediate structure Query structure to set Application data structures Update intermediate structure with changed values from Application data convert intermediate structure back to a config file Here, the intermediate structure can remember the comments in the initial file and thus preserve them. But, IMO, this is also less clean and more complex than the first method, as you have an additional thing to carry around, and the potential to forget to do that "update" part. There is another method that I use. Read the entire file and return a single element (or maybe more) whenever access to an element is required. This relies on OS caching to maintain performance but yields real-time, on-the-fly changes to the ini file being reflected in the application. Quote
Phillip Brooks Posted April 12, 2021 Report Posted April 12, 2021 On 4/6/2021 at 11:47 AM, drjdpowell said: Note: that package also has RFC3339-compliant Datetime format VIs, if you haven't already done Timestamps. See my signature 1 Quote
Popular Post Antoine Chalons Posted April 16, 2021 Author Popular Post Report Posted April 16, 2021 I've fixed quite a few bugs and changed the way timestamps are handled, now using JDP Science Common VIs for RFC-3339 You can follow on GitHub 2 1 Quote
ShaunR Posted April 17, 2021 Report Posted April 17, 2021 What a horrendous format TOML is. I won't be using this format unless forced to at knife-point. 1 Quote
Antoine Chalons Posted April 17, 2021 Author Report Posted April 17, 2021 I've had some difficult clients in the past but it never got to that point 🤣 Quote
Porter Posted December 13, 2021 Report Posted December 13, 2021 It seems that there are now two forks of the erdosmiller TOML library: https://github.com/AntoineChalons/lv-toml https://github.com/justiceb/BlueTOMLSerializer @bjustice is the BlueTOML a fork of the original erdosmiller library or of Antoine's library? Quote
Antoine Chalons Posted December 13, 2021 Author Report Posted December 13, 2021 (edited) I'm pretty sure I read somewhere that he started from the erdosmiller TOML library Edit : I knew : Edited December 13, 2021 by Antoine Chalons Quote
bjustice Posted December 13, 2021 Report Posted December 13, 2021 @Porter @Antoine Chalons There's some background info here. A few things. Both of those libraries are branches of the Erdos Miller code. However, I communicated all of my modifications to Antoine, who then re-implemented them in his library. I have little intention of making additional changes to my branch. Conversely, I suspect that Antoine intends to continue to support his branch, if only in a limited manner. BlueTOMLSerializer is not just a TOML library. It was written as a TOML-based plugin for the BlueSerialization engine. https://www.vipm.io/package/blue_origin_lib_blueserialization/ This is a large piece of code that handles serialization and deserialization of classes quite well. The user can select an implementation of JSON, TOML, or other by choosing a different plugin library. I fully intend to modify BlueTOMLSerializer to drop all the TOML code and directly consume Antoine's library as a dependency. This, for example, is what I do for JSONtext. Unfortunately, I'm waiting on a specific feature request to be implemented in Antoine's library: https://github.com/AntoineChalons/lv-toml/issues/24 Hope this helps 1 Quote
Porter Posted December 13, 2021 Report Posted December 13, 2021 47 minutes ago, bjustice said: I fully intend to modify BlueTOMLSerializer to drop all the TOML code and directly consume Antoine's library as a dependency. That's what I was thinking. Thanks for the clarification. Quote
Antoine Chalons Posted December 13, 2021 Author Report Posted December 13, 2021 1 hour ago, bjustice said: Unfortunately, I'm waiting on a specific feature request to be implemented in Antoine's library: https://github.com/AntoineChalons/lv-toml/issues/24 Maybe for xmas Quote
Betty_Green_ Posted January 28, 2022 Report Posted January 28, 2022 Thanks for the information! Quote
Antoine Chalons Posted November 21, 2022 Author Report Posted November 21, 2022 new release in my fork : https://github.com/AntoineChalons/lv-toml/releases/tag/releases%2Fv2.3.2 what's new : I've improved the error reporting when there is a typo in the value, ex : [cluster] some-numerial-value = 10 other-numerial-value-with-a-typo = 10s The error source will quote the line at fault and give you the line index, something like "Parsing error at line 3 : 'other-numerical-value-with-a-typo = 10s' 2 Quote
Popular Post Jim Kring Posted July 18, 2023 Popular Post Report Posted July 18, 2023 (edited) Adding a link to this new tool: TOML Edit LabVIEW it is a thin wrapper around a popular Rust library that supports preservation of formatting and comments. Edited July 18, 2023 by Jim Kring 3 Quote
