Rolf Kalbermatter Posted 22 hours ago Report Posted 22 hours ago (edited) LabVIEW 5 is almost 30 years old! It won't run on any modern computer very well if at all. Besides offering software even if that old like this is not just maybe illegal but definitely. So keep browsing your Russian crack sites but leave your offerings away from this site, please! Edited 22 hours ago by Rolf Kalbermatter Quote
Tom Eilers Posted 9 hours ago Report Posted 9 hours ago LabView 5.1 runs prefect on a windows 11 pro. The nice thing about LabView 5.x and maybe older, that is run from an USB stick. See picture Quote
Rolf Kalbermatter Posted 4 hours ago Report Posted 4 hours ago 4 hours ago, Tom Eilers said: LabView 5.1 runs prefect on a windows 11 pro. The nice thing about LabView 5.x and maybe older, that is run from an USB stick. See picture I know it runs (mostly), installation is a slightly different story. But that's still no justification to promote pirated software no matter how old. Quote
dadreamer Posted 3 hours ago Report Posted 3 hours ago I have LabVIEW 5 and 6 on my USB stick too and they both run OK on Windows 10. Initially LV 5 was hanging at the start, so I had to disable multithreading: ESys.StdNParallel=0 Not that I really need LabVIEW to be on hand all the time. But sometimes it's useful to have around an advanced calculator for quick-n-dirty prototyping. And sometimes to look at how things were then. Considering the age and bugs, using these versions for serious projects is, to put it mildly, unwise. I also don't like that LabVIEW re-registers file associations for itself every time it starts, but I'm more or less used to this. I also believe, those versions didn't really need some pirate tools. Just owner's personal data and serial number were needed. If not available, it was possible to use 'an infinite trial' mode: start, click OK and do everything you want. Quote
Rolf Kalbermatter Posted 3 hours ago Report Posted 3 hours ago (edited) 26 minutes ago, dadreamer said: I also believe, those versions didn't really need some pirate tools. Just owner's personal data and serial number were needed. If not available, it was possible to use 'an infinite trial' mode: start, click OK and do everything you want. True there is no active license checking in LabVIEW until 7.1. And as you say, using LabVIEW 5 or 6 as a productive tool is not wise, neither is blabbing about Russian hack sites here. What someone installs on his own computer is his own business but expecting such hacks to be done out of pure love for humanity is very naive. If someone is able to circumvent the serial check somehow (not a difficult task) they are also easily able to add some extra payload into the executable that does things you rather would not want done on your computer. Edited 3 hours ago by Rolf Kalbermatter Quote
hooovahh Posted 1 hour ago Report Posted 1 hour ago A11A11111, or any such alpha-numeric serial from that era worked. For a while at the company I was working at, we would enter A11A11111 as a key, then not activate, then go through the process of activating offline, by sending NI the PC's unique 20 (25?) digit code. This would then activate like it should but with the added benefit of not putting the serial you activated with on the splash screen. We would got to a conference or user group to present, and if we launched LabVIEW, it would pop up with the key we used to activate all software we had access to. Since then there is an INI key I think that hides it, but here is an idea exchange I saw on it. LabVIEW 5 EXEs also ran without needing to install the runtime engine. LabVIEW 6 and 7 EXEs could run without installing the runtime engine if you put files in special locations. Here is a thread, where the PDF that explains it is missing but the important information remains. Quote
