Rolf Kalbermatter Posted January 1 Report Posted January 1 (edited) LabVIEW 5 is almost 30 years old! It won't run on any modern computer very well if at all. Besides offering software even if that old like this is not just maybe illegal but definitely. So keep browsing your Russian crack sites but leave your offerings away from this site, please! Edited January 1 by Rolf Kalbermatter Quote
Tom Eilers Posted January 2 Report Posted January 2 LabView 5.1 runs prefect on a windows 11 pro. The nice thing about LabView 5.x and maybe older, that is run from an USB stick. See picture Quote
Rolf Kalbermatter Posted January 2 Report Posted January 2 4 hours ago, Tom Eilers said: LabView 5.1 runs prefect on a windows 11 pro. The nice thing about LabView 5.x and maybe older, that is run from an USB stick. See picture I know it runs (mostly), installation is a slightly different story. But that's still no justification to promote pirated software no matter how old. Quote
dadreamer Posted January 2 Report Posted January 2 I have LabVIEW 5 and 6 on my USB stick too and they both run OK on Windows 10. Initially LV 5 was hanging at the start, so I had to disable multithreading: ESys.StdNParallel=0 Not that I really need LabVIEW to be on hand all the time. But sometimes it's useful to have around an advanced calculator for quick-n-dirty prototyping. And sometimes to look at how things were then. Considering the age and bugs, using these versions for serious projects is, to put it mildly, unwise. I also don't like that LabVIEW re-registers file associations for itself every time it starts, but I'm more or less used to this. I also believe, those versions didn't really need some pirate tools. Just owner's personal data and serial number were needed. If not available, it was possible to use 'an infinite trial' mode: start, click OK and do everything you want. Quote
Rolf Kalbermatter Posted January 2 Report Posted January 2 (edited) 26 minutes ago, dadreamer said: I also believe, those versions didn't really need some pirate tools. Just owner's personal data and serial number were needed. If not available, it was possible to use 'an infinite trial' mode: start, click OK and do everything you want. True there is no active license checking in LabVIEW until 7.1. And as you say, using LabVIEW 5 or 6 as a productive tool is not wise, neither is blabbing about Russian hack sites here. What someone installs on his own computer is his own business but expecting such hacks to be done out of pure love for humanity is very naive. If someone is able to circumvent the serial check somehow (not a difficult task) they are also easily able to add some extra payload into the executable that does things you rather would not want done on your computer. Edited January 2 by Rolf Kalbermatter Quote
hooovahh Posted January 2 Report Posted January 2 A11A11111, or any such alpha-numeric serial from that era worked. For a while at the company I was working at, we would enter A11A11111 as a key, then not activate, then go through the process of activating offline, by sending NI the PC's unique 20 (25?) digit code. This would then activate like it should but with the added benefit of not putting the serial you activated with on the splash screen. We would got to a conference or user group to present, and if we launched LabVIEW, it would pop up with the key we used to activate all software we had access to. Since then there is an INI key I think that hides it, but here is an idea exchange I saw on it. LabVIEW 5 EXEs also ran without needing to install the runtime engine. LabVIEW 6 and 7 EXEs could run without installing the runtime engine if you put files in special locations. Here is a thread, where the PDF that explains it is missing but the important information remains. Quote
ShaunR Posted January 3 Report Posted January 3 17 hours ago, Rolf Kalbermatter said: What someone installs on his own computer is his own business Tell that to Microsoft. 17 hours ago, Rolf Kalbermatter said: they are also easily able to add some extra payload into the executable that does things you rather would not want done on your computer. Again. Tell that to Microsoft. I'm afraid the days of preaching from a higher moral ground on behalf of corporations is very much a historical artifact right now. Quote
ShaunR Posted January 3 Report Posted January 3 (edited) 16 hours ago, hooovahh said: A11A11111, or any such alpha-numeric serial from that era worked. For a while at the company I was working at, we would enter A11A11111 as a key, then not activate, then go through the process of activating offline, by sending NI the PC's unique 20 (25?) digit code. This would then activate like it should but with the added benefit of not putting the serial you activated with on the splash screen. We would got to a conference or user group to present, and if we launched LabVIEW, it would pop up with the key we used to activate all software we had access to. Since then there is an INI key I think that hides it, but here is an idea exchange I saw on it. LabVIEW 5 EXEs also ran without needing to install the runtime engine. LabVIEW 6 and 7 EXEs could run without installing the runtime engine if you put files in special locations. Here is a thread, where the PDF that explains it is missing but the important information remains. The thing I loved about the original LabVIEW was that it was not namespaced or partitioned. You could run an executable and share variables without having to use things like memory maps. I used to to have a toolbox of executables (DVM, Power Supplies, oscilloscopes, logging etc. ) and each test system was just launching the appropriate executable[s] at the appropriate times. It was like OOP composition for an entire test system but with executable modules. Additionally, crashes were unheard of. In the 1990's I think I had 1 insane object in 18 months and didn't know what a GPF fault was until I started looking at other languages. We could run out of memory if we weren't careful though (remember the Bulldozer?). Progress! Edited January 3 by ShaunR 1 Quote
Rolf Kalbermatter Posted January 3 Report Posted January 3 (edited) 1 hour ago, ShaunR said: The thing I loved about the original LabVIEW was that it was not namespaced or partitioned. You could run an executable and share variables without having to use things like memory maps. I used to to have a toolbox of executables (DVM, Power Supplies, oscilloscopes, logging etc. ) and each test system was just launching the appropriate executable[s] at the appropriate times. It was like OOP composition for an entire test system but with executable modules. One BBF (Big Beauttiful F*cking) Global Namespace may sound like a great feature but is a major source of all kinds of problems. From a certain system size it is getting very difficult to maintain and extend it for any normal human, even the original developer after a short period. Quote Additionally, crashes were unheard of. In the 1990's I think I had 1 insane object in 18 months and didn't know what a GPF fault was until I started looking at other languages. We could run out of memory if we weren't careful though (remember the Bulldozer?). When I read this I was wondering what might cause the clear misalignment of experience here with my memory. 1) It was ironically meant and you forgot the smiley 2) A case of rosy retrospection 3) Or are we living in different universes with different physical laws for computers LabVIEW 2.5 and 3 were a continuous stream of GPFs, at times so bad that you could barely do some work in them. LabVIEW 4 got somewhat better but was still far from easy sailing. 5 and especially 5.1.1 was my first long term development platform. Not perfect for sure but pretty usable. But things like some specific video drivers for sure could send LabVIEW frequently belly up as could more complicated applications with external hardware (from NI). 6i was a gimmick, mainly to appease the internet hype, not really bad bad far from stable. 7.1.1 ended up to be my next long term development platform. Never touched 8.0 and only briefly 8.2.1 which was required for some specific real-time hardware. 8.6.1 was the next version that did get some use from me. But saying that LabVIEW never crashed on me in the 90ies, even with leaving my own external code experiments aside, would be a gross under-exaggeration. And working in the technical support of NI from 1992 to 1996 for sure made me see many many more crashes in that time. Edited January 3 by Rolf Kalbermatter Quote
ShaunR Posted January 3 Report Posted January 3 (edited) 2 hours ago, Rolf Kalbermatter said: From a certain system size it is getting very difficult to maintain and extend it for any normal human, even the original developer after a short period. Gotta disagree here (surprise!) Take a look at the modern 20k VI monstrosities people are trying to maintain now so as to be in with the cool cats of POOP. I had a VI for every system device type and if they bought another DVM, I'd modify that exe to cater for it. It was perfect modularisation at the device level and modifying the device made no difference to any of the other exe's. Now THAT was encapsulation and the whole test system was about 100 VI's. They are called VI's because it stood for "Virtual Instruments" and that's exactly what they were and I would assemble a virtual test bench from them. 2 hours ago, Rolf Kalbermatter said: When I read this I was wondering what might cause the clear misalignment of experience here with my memory. 1) It was ironically meant and you forgot the smiley 2) A case of rosy retrospection 3) Or are we living in different universes with different physical laws for computers Defintely 3). LabVIEW was the first ever programming language I learned when I was a quality engineer so as to automate environmental and specification testing. While I (Quality Engineering) was building up our test capabilities we would use the Design Engineering test harnesses to validate the specifications. I was tasked with replacing the Design Engineering white-box tests with our own black-box ones (the philosophy was to use dissimilar tools to the Design Engineers and validate code paths rather than functions, which their white-box testing didn't do). Ours were written in LabVIEW and theirs was written in C. I can tell you now that their test harnesses had more faults than the Pacific Ocean. I spent 80% of my time trying to get their software to work and another 10% getting them to work reliably over weekends. The last 10% was spent arguing with Engineering when I didn't get the same results as their specification That all changed when moving to LabVIEW. It was stable, reliable and predictable. I could knock up a prototype in a couple of hours on Friday and come back after the weekend and look at the results. By first break I could wander down to the design team and tell them it wasn't going on the production line . That prototype would then be refined, improved and added to the test suite. I forget the actual version I started with but it was on about 30 floppy disks (maybe 2.3 or around there). If you have seen desktop gadgets in Windows 7, 10 or 11 then imagine them but they were VI's. That was my desktop in the 1990's. DVM, Power Supply, and graphing desktop gadgets that ran continuously and I'd launch "tests" to sequence the device configurations and log the data. I will maintain my view that the software industry has not improved in decades and any and all perceived improvements are parasitic of hardware improvements. When I see what people were able to do in software with 1960's and 80's hardware; I feel humbled. When I see what they are able to do with software in the 2020's; I feel despair. 2 hours ago, Rolf Kalbermatter said: One BBF (Big Beauttiful F*cking) Global Namespace I had a global called the "BFG" (Big F#*king Global). It was great. It was when I was going through my "Data Pool" philosophy period. Edited January 3 by ShaunR Quote
Rolf Kalbermatter Posted January 3 Report Posted January 3 (edited) Ok, you should have specified that you were comparing it with tools written in C 🙂 The typical test engineer has definitely no idea about all the possible ways C code can be made to trip over its feet and back then it was even less understood and frameworks that could help alleviate the issue were sparse and far between. What I could not wrap my head around was your claim that LabVIEW never would crash. That's very much controversial to my own experience. 😁 Especially if you make it sound like it is worse nowadays. It's definitely not but your typical use cases are for sure different nowadays than they were back then. And that is almost certainly the real reason you may feel LabVIEW crashes more today then it did back then. Edited January 3 by Rolf Kalbermatter Quote
ShaunR Posted January 4 Report Posted January 4 (edited) 15 hours ago, Rolf Kalbermatter said: What I could not wrap my head around was your claim that LabVIEW never would crash. It just didn't. Like I said. I only got the out of memory when I was trying to load large amounts of data. I suppose you could consider that a crash but there was never any instance of LabVIEW just disappearing like it does nowadays. I only saw the "insane object" two or three times in my whole Quality Engineering career and LabVIEW certainly didn't take down the Windows OS like some of the C programs did regularly. But I can understand you having different experiences. I've come to the conclusion, over the years, that my unorthodox workflows and refusal to be on the bleeding edge of technology, shield me from a lot of the issues people raise. Edited January 4 by ShaunR Quote
dadreamer Posted January 6 Report Posted January 6 On 1/2/2026 at 11:55 PM, hooovahh said: LabVIEW 5 EXEs also ran without needing to install the runtime engine. From what I can remember, for LV 5.0.x and older RTE (i.e., a loader plus small subset of resources) was included into the EXE automatically during the build process. For LV 5.1.x there was a choice: to include RTE into the build or to use an external RTE. And since LV 6.0 only an external RTE was supposed. On 1/2/2026 at 11:55 PM, hooovahh said: LabVIEW 6 and 7 EXEs could run without installing the runtime engine if you put files in special locations. Here is a thread, where the PDF that explains it is missing but the important information remains. I could say more, such a trick is still possible for all modern versions on all three platforms (Win, Mac, Linux). The latest version I tested it on, was LV 2018, but I'm pretty sure, the technique hasn't changed much. I can't remember, from which version NI started to use Visual Studio 2015, but since then each EXE requires The Universal CRT, that is contained in Microsoft Visual C++ 2015 Redistributable. One could install such a distro on a clean machine or copy all these files from the machine, where such a CRT is already installed. Quote api_ms_win_core_console_l1_1_0.dll api_ms_win_core_datetime_l1_1_0.dll api_ms_win_core_debug_l1_1_0.dll api_ms_win_core_errorhandling_l1_1_0.dll api_ms_win_core_file_l1_1_0.dll api_ms_win_core_file_l1_2_0.dll api_ms_win_core_file_l2_1_0.dll api_ms_win_core_handle_l1_1_0.dll api_ms_win_core_heap_l1_1_0.dll api_ms_win_core_interlocked_l1_1_0.dll api_ms_win_core_libraryloader_l1_1_0.dll api_ms_win_core_localization_l1_2_0.dll api_ms_win_core_memory_l1_1_0.dll api_ms_win_core_namedpipe_l1_1_0.dll api_ms_win_core_processenvironment_l1_1_0.dll api_ms_win_core_processthreads_l1_1_0.dll api_ms_win_core_processthreads_l1_1_1.dll api_ms_win_core_profile_l1_1_0.dll api_ms_win_core_rtlsupport_l1_1_0.dll api_ms_win_core_string_l1_1_0.dll api_ms_win_core_synch_l1_1_0.dll api_ms_win_core_synch_l1_2_0.dll api_ms_win_core_sysinfo_l1_1_0.dll api_ms_win_core_timezone_l1_1_0.dll api_ms_win_core_util_l1_1_0.dll api_ms_win_crt_conio_l1_1_0.dll api_ms_win_crt_convert_l1_1_0.dll api_ms_win_crt_environment_l1_1_0.dll api_ms_win_crt_filesystem_l1_1_0.dll api_ms_win_crt_heap_l1_1_0.dll api_ms_win_crt_locale_l1_1_0.dll api_ms_win_crt_math_l1_1_0.dll api_ms_win_crt_multibyte_l1_1_0.dll api_ms_win_crt_private_l1_1_0.dll api_ms_win_crt_process_l1_1_0.dll api_ms_win_crt_runtime_l1_1_0.dll api_ms_win_crt_stdio_l1_1_0.dll api_ms_win_crt_string_l1_1_0.dll api_ms_win_crt_time_l1_1_0.dll api_ms_win_crt_utility_l1_1_0.dll concrt140.dll msvcp140.dll ucrtbase.dll vcamp140.dll vccorlib140.dll vcomp140.dll vcruntime140.dll Now besides of those the application will also require this minimal subset of folders/files (true for LV 2018 64-bit): Quote English errors (to get meaningful error descriptions, reported by the error handler) models lvrt.dll mesa.dll nicont.dll niCPULib.dll nierInterface.dll NILVRuntimeManager.dll (to get the dialogs about missing DLL's displayed at the start; could be excluded) NIQtCore_2018.dll NIQtGui_2018.dll QtManager452_2018.dll tdtable.tdr On Linux it goes much easier (true for LV 2014 64-bit): Quote English models liblvrt.so.14.0 (liblvrt.so.14.0.0) libniCPULib.so (libniCPULib.so.14.0.0) tdtable.tdr For LV 2018 64-bit with a "dark" RTE it also wants Quote liblvrtdark.so.18.0 libNILVRuntimeManager.so rtapp.rsc And for Mac OS you can embed RTE into the application with this script: Standalone LabVIEW-built Mac Application with Post-Build Action. Of course (and I'm sure everyone understands that), the technique described above, is applicable to very simple 'a la calculator' apps and not very to not at all for more or less complex projects. The more functions are called, the more dependencies you get. If something from MKL is used, you need lvanlys.dll and LV##0000_BLASLAPACK.dll, if VISA is used, you need visa32.dll, NiViAsrl.dll and maybe others, and so on and so forth. 1 Quote
