Rolf Kalbermatter Posted June 4, 2025 Report Posted June 4, 2025 I believe that I was able to edit in the past posts even if they were older. Just came across one of my posts with a typo and when I tried to edit it, the Edit command is not present anymore. Is that a recent change, or am I just hallucinating due to old age? Quote
hooovahh Posted June 4, 2025 Report Posted June 4, 2025 I am unaware of a time limit on editing your own posts. You are welcome to use the report to moderator to make fixes. I realize small things are just easier to ignore than making a report. Quote
Rolf Kalbermatter Posted June 4, 2025 Author Report Posted June 4, 2025 (edited) Unless I'm completely hallucinating, there used to be an Edit command in this pulldown menu. And it is now for this post, but not for the previous one. Edited June 4, 2025 by Rolf Kalbermatter Quote
Neil Pate Posted June 4, 2025 Report Posted June 4, 2025 @Rolf Kalbermatter the admins removed that setting for you as everything you say should be written down and never deleted 🙂 1 Quote
Rolf Kalbermatter Posted June 4, 2025 Author Report Posted June 4, 2025 6 minutes ago, Neil Pate said: @Rolf Kalbermatter the admins removed that setting for you as everything you say should be written down and never deleted 🙂 Drat, and now my typos and errors are put in stone for eternity (well at least until LavaG is eventually shutdown when the last person on earth turns off the light) 😁 1 Quote
X___ Posted June 4, 2025 Report Posted June 4, 2025 There is no typos and errors in your posts. Only pearls of wisdom and oracles of truth that we mortals can't understand yet... 1 Quote
ShaunR Posted June 6, 2025 Report Posted June 6, 2025 On 6/4/2025 at 4:51 PM, Rolf Kalbermatter said: Drat, and now my typos and errors are put in stone for eternity (well at least until LavaG is eventually shutdown when the last person on earth turns off the light) 😁 Those aren't typo's and errors. They are tests to see if we are paying attention. 2 Quote
