crelf Posted November 8, 2007 Report Share Posted November 8, 2007 Now that I've got your attention: no, this isn't an OO question. Consider a VI that has a required input. If I then drop that VI (child) into another VI (parent), create a control that wires into the required input of the subVI and then put that control on the parent's connector pane, should the parent's connector pane node become required? A is required, should B be automatically required too? Quote Link to comment
JDave Posted November 8, 2007 Report Share Posted November 8, 2007 QUOTE(crelf @ Nov 7 2007, 11:11 AM) Now that I've got your attention: no, this isn't an OO question. Consider a VI that has a required input. If I then drop that VI (child) into another VI (parent), create a control that wires into the required input of the subVI and then put that control on the parent's connector pane, should the parent's connector pane node become required?A is required, should B be automatically required too? My first thought is that this sounds like a good candidate for a VI Analyzer test, not automatic behavior within the IDE. Quote Link to comment
Justin Goeres Posted November 8, 2007 Report Share Posted November 8, 2007 I'm really of two minds about this. The core of your question, I think, comes from the experience we've all had of creating a control on subVI A that we're just going to wire to a terminal on the parent VI B. If A is required, and you want B to be required, it takes what, like like four extra operations to set that behavior??? That's pretty poor usability for an operation some of us have probably done hundreds of thousands of times. But making required inputs on a subVI automatically drop as required inputs on a parent VI really just trades one side of the problem for the other side. I can't say for sure how often I want those parent inputs to be Required. I'd guess it's more than 50% of the time, but I dunno if it's as high as 75%. The other 25-50% of the time, I probably want them not to be Required. So I would probably lean toward saying in your scenario they should be "Required," but I certainly can see other people coming down on the other side of the fence. Wouldn't it be nice is the whole "connecting terminals to the connector pane and setting their attributes" process was easier in the first place, given that it's kind of a core concept of the language? Quote Link to comment
eaolson Posted November 8, 2007 Report Share Posted November 8, 2007 QUOTE(crelf @ Nov 7 2007, 01:11 PM) Now that I've got your attention: no, this isn't an OO question. Consider a VI that has a required input. If I then drop that VI (child) into another VI (parent), create a control that wires into the required input of the subVI and then put that control on the parent's connector pane, should the parent's connector pane node become required? I would say no. There are plenty of cases where the parent VI could put an acceptable default for the control, which didn't need to be wired. Take VISA Configure Serial Port as an example. (That VI uses a property node, which can basically be treaded as a subVI with required inputs.) The Configure VI has many default values which usually don't need to be changed. Quote Link to comment
LAVA 1.0 Content Posted November 8, 2007 Report Share Posted November 8, 2007 QUOTE(crelf @ Nov 7 2007, 02:11 PM) Now that I've got your attention: no, this isn't an OO question. Consider a VI that has a required input. If I then drop that VI (child) into another VI (parent), create a control that wires into the required input of the subVI and then put that control on the parent's connector pane, should the parent's connector pane node become required?A is required, should B be automatically required too? http://lavag.org/old_files/monthly_11_2007/post-181-1194462684.gif' target="_blank"> Only if the child VI is moves on to meet the Supreme Wire-worker. Seriously, The use of controls to provide a default value when un-wired is such a nice behaviour that I would not want to have to take extra steps to use it. Ben Quote Link to comment
Götz Becker Posted November 8, 2007 Report Share Posted November 8, 2007 I would not want such a behavior. The LV 8.5 option to make connector required by default is really good, but my guess is that teaching this new thing to the compiler and the users, exactly when this should happen would induce more problems than it might solve. 2 usecases I came up with: Quote Link to comment
Ton Plomp Posted November 8, 2007 Report Share Posted November 8, 2007 What might be better is an easier way to make a terminal switch between 'Recommended' and 'Required', ctrl-click maybe? Ton Quote Link to comment
crelf Posted November 8, 2007 Author Report Share Posted November 8, 2007 QUOTE(Justin Goeres @ Nov 8 2007, 05:32 AM) ...I can't say for sure how often I want those parent inputs to be Required. I'd guess it's more than 50% of the time, but I dunno if it's as high as 75%. The other 25-50% of the time, I probably want them not to be Required. In the words of all 2 years old: "But whhhyyyyy?" As I said, it's philopsphical: what use cases exist when you don't want a subVI's requiredness to propagate to a calling VI's requiredness? What I'm talking about is a subVI that's in a VI that will ultimately be used as a subVI. Quote Link to comment
Götz Becker Posted November 8, 2007 Report Share Posted November 8, 2007 QUOTE(crelf @ Nov 7 2007, 11:16 PM) 3. If it's required, then the 'requiredness' attribute propagates upward until it's satisfied (that means keep on going up until there's an explicit non-default data source). Would you then want the 'requiredness' attribute propagate into two inputs of the parent VI, if the input into child is calculated out of those, as well? I hope this sentence makes any sense!?! This is the first time I try to philosophize in english Quote Link to comment
crelf Posted November 8, 2007 Author Report Share Posted November 8, 2007 QUOTE(Götz Becker @ Nov 8 2007, 09:08 AM) Would you then want the 'requiredness' attribute propagate into two inputs of the parent VI, if the input into child is calculated out of those, as well? Exactly! If we followed this rule, then all branches back through the dataflow would need to conform to the 'requiredness' of the child! (I said it was a philisophical question so I'm not interested in the paltry issues of implementation at this stage ) QUOTE(Götz Becker @ Nov 8 2007, 09:08 AM) I hope this sentence makes any sense!?! This is the first time I try to philosophize in english You did great :thumbup: Quote Link to comment
Aristos Queue Posted November 9, 2007 Report Share Posted November 9, 2007 QUOTE(crelf @ Nov 7 2007, 04:16 PM) Whilst I appreciate the sentiment, gimme a use case! Open TCP/IP prim has a required "port" input. But the VI for connecting to the web has an optional input for "port" -- it defaults to port 80. You can still provide a port, but in that case, most of the time the default is fine. So use case is anytime a generic API is used in a specific context, there may be a 90% use case for the specific case, but there's no such for the general case. So you make it optional in specific and required in generic. Quote Link to comment
crelf Posted November 9, 2007 Author Report Share Posted November 9, 2007 QUOTE(Aristos Queue @ Nov 8 2007, 02:00 PM) Open TCP/IP prim has a required "port" input... So use case is anytime a generic API is used in a specific context, there may be a 90% use case for the specific case, but there's no such for the general case. Right - that's exactly what I was looking for - thanks. Quote Link to comment
Norm Kirchner Posted November 9, 2007 Report Share Posted November 9, 2007 QUOTE(crelf @ Nov 7 2007, 01:11 PM) Now that I've got your attention: no, this isn't an OO question. Consider a VI that has a required input. If I then drop that VI (child) into another VI (parent), create a control that wires into the required input of the subVI and then put that control on the parent's connector pane, should the parent's connector pane node become required?A is required, should B be automatically required too? I would have to say that the parent will never adopt the better practices of the child as the parent will see the innovative things that the children do as cute and truly excessive as all parents know everything and need to never adapt and grow and change. That would be just silly. Heck, if a parent actually changed because of the child... shit... the universe would swallow itself whole. No.... no.... it's much better if the natural order stays the same and the world can only get better by waiting for the old generations to die off and let the new generations fix their mistakes and eventurally not change for the following generation. ..... i have issues Quote Link to comment
crelf Posted November 9, 2007 Author Report Share Posted November 9, 2007 QUOTE(Norm Kirchner @ Nov 8 2007, 02:46 PM) No.... no.... it's much better if the natural order stays the same and the world can only get better by waiting for the old generations to die off and let the new generations fix their mistakes and eventurally not change for the following generation. You're soooooo needy. Quote Link to comment
LAVA 1.0 Content Posted November 9, 2007 Report Share Posted November 9, 2007 QUOTE(Norm Kirchner @ Nov 7 2007, 11:46 PM) ... the world can only get better by waiting for the old generations to die off and let the new generations fix their mistakes.... That's what the hippies said and look at the mess we are in now that they are in charge! Ben Quote Link to comment
crelf Posted November 9, 2007 Author Report Share Posted November 9, 2007 QUOTE(neB @ Nov 9 2007, 03:41 AM) That's what the hippies said and look at the mess we are in now that they are in charge Oooooooooo - I wanted a philisophical discussion, but didn't quite expect this! Maybe we should move that one to the lounge in its own thread? Quote Link to comment
Jim Kring Posted November 9, 2007 Report Share Posted November 9, 2007 QUOTE(crelf @ Nov 7 2007, 11:11 AM) Now that I've got your attention: no, this isn't an OO question. Consider a VI that has a required input. If I then drop that VI (child) into another VI (parent), create a control that wires into the required input of the subVI and then put that control on the parent's connector pane, should the parent's connector pane node become required?A is required, should B be automatically required too? http://lavag.org/old_files/monthly_11_2007/post-181-1194462684.gif' target="_blank"> What you're talking about is akin to dynamic type propagation -- we've discussed having typeless/polymorphic controls/indicators/wire before. Quote Link to comment
shoneill Posted November 9, 2007 Report Share Posted November 9, 2007 QUOTE(Norm Kirchner @ Nov 8 2007, 05:46 AM) I would have to say that the parent will never adopt the better practices of the child as the parent will see the innovative things that the children do as cute and truly excessive as all parents know everything and need to never adapt and grow and change. That would be just silly. Heck, if a parent actually changed because of the child... shit... the universe would swallow itself whole. No.... no.... it's much better if the natural order stays the same and the world can only get better by waiting for the old generations to die off and let the new generations fix their mistakes and eventurally not change for the following generation...... i have issues You have Issues? To me sounds like you have KIDS!!! Shane. Quote Link to comment
crelf Posted November 9, 2007 Author Report Share Posted November 9, 2007 QUOTE(shoneill @ Nov 9 2007, 07:04 AM) You have Issues? To me sounds like you have KIDS!!! Same thing. QUOTE(Jim Kring @ Nov 9 2007, 04:45 AM) What you're talking about is akin to dynamic type propagation... It is in the sense of the propagation, but not the typelessness (is that a word?) What I'm interested in hearing is input on an even-more strictly typed type. Quote Link to comment
