Popular Post MikaelH Posted August 30, 2011 Popular Post Report Posted August 30, 2011 Hi guys How do you measure execution times/performance? I have 3 favourites. The Profiler (Profile Performance and Memory) Desktop Execution Trace toolkit (it give um timing accuracy very nice ) And a Timing Probe (see attached VIs) How do you do it? Timing Probe (Error).vi TimingProbe_Kernel.vi Cheers, Mike 5 Quote
Grampa_of_Oliva_n_Eden Posted August 31, 2011 Report Posted August 31, 2011 I avoid construct that kill time like the plague so it has been a while since I had to do benchmarks on code perfomance (it problably has more to do with faster CPUs than my imporved coiding techniques I freely admit) but when I did I used the seq frame with ms tick counts. But, I kept performance in mind as I have been developing and buried in the "top-level" Hardware Class (from which most of my widgets inherit) there is an optional built-in timing functions so I can turn on the time logging functions. I hope I never have to use them! Ben Quote
Ulf Posted August 31, 2011 Report Posted August 31, 2011 Hi, Another question, how do you measure the "CPU-usage" in a VI? Regards Ulf Quote
Mellroth Posted August 31, 2011 Report Posted August 31, 2011 I just learned about this little guy at NI-Week this year, I have only tested it briefly so far, but I believe you get us resolution with this as well. /J 2 Quote
Tim_S Posted August 31, 2011 Report Posted August 31, 2011 On 8/31/2011 at 1:14 PM, Ulf said: Hi, Another question, how do you measure the "CPU-usage" in a VI? Task manager gives a general idea. The Tools->Profile->Performance and Memory menu option gives a good idea of where that CPU time is going. Tim Quote
MikaelH Posted August 31, 2011 Author Report Posted August 31, 2011 On 8/31/2011 at 1:14 PM, Ulf said: Another question, how do you measure the "CPU-usage" in a VI? Ulf, try the Desktop Execution Trace toolkit, it gives you info which CPU runs which VI. On 8/31/2011 at 1:46 PM, Mellroth said: I just learned about this little guy at NI-Week this year, I have only tested it briefly so far, but I believe you get us resolution with this as well. /J Cool I'll give it a try. //Mike Quote
Ulf Posted September 1, 2011 Report Posted September 1, 2011 Mikael, Does the "Desktop Execution Trace Toolkit" give information about CPU-load? I can only see the CPU Id... Found a nice GUI-bug, although, in the toolkit when I expanded it to full-screeen on a "vertical" display. I seems like the toolkit is built in LabVIEW.... You can see a "local" 1D-array of enums in the left down corner of the application. //Ulf Quote
MikaelH Posted September 1, 2011 Author Report Posted September 1, 2011 On 9/1/2011 at 8:42 AM, Ulf said: Does the "Desktop Execution Trace Toolkit" give information about CPU-load? No not what I know about. On 9/1/2011 at 8:42 AM, Ulf said: I seems like the toolkit is built in LabVIEW Your right, and it's very impressing LV application, it's written in LV 8.6 :-) Cheers, Mike Quote
Mark Balla Posted September 1, 2011 Report Posted September 1, 2011 On 8/31/2011 at 1:46 PM, Mellroth said: I just learned about this little guy at NI-Week this year, I have only tested it briefly so far, but I believe you get us resolution with this as well. /J I wouldn't rely on it too much. There is a reason it is not in the pallet I remember this issue being discussed previously. From this simple test vi I built you can see that it is very inconsistent compared to the other methods. I am curious to know what NI Week session discussed this vi. My guess is that is is designed for RT targets. Mark Quote
drjdpowell Posted September 1, 2011 Report Posted September 1, 2011 On 9/1/2011 at 12:47 PM, Mark Balla said: From this simple test vi I built you can see that it is very inconsistent compared to the other methods. The other two methods aren't precise enough to see the <0.5ms variation in times. The ms timer can only time to the millisecond, and the datetime is even less accurate. Quote
Samapico Posted September 1, 2011 Report Posted September 1, 2011 (edited) On 9/1/2011 at 1:12 PM, drjdpowell said: The other two methods aren't precise enough to see the <0.5ms variation in times. The ms timer can only time to the millisecond, and the datetime is even less accurate. Yeah... take a look at the attached image. The datetime makes you think it's accurate by showing a bunch of decimals, but it still has a ~1ms resolution. The example you posted actually proves that the high res timer IS way more accurate. More accurate than the wait(ms) VI anyway Edit: Using the same kind of code, the resolution of the high res timer is about ~0.31106 microseconds, or 3.1106 E-7 seconds. Pretty cool, imo. Edited September 1, 2011 by Samapico Quote
asbo Posted September 1, 2011 Report Posted September 1, 2011 On 9/1/2011 at 2:03 PM, Samapico said: Yeah... take a look at the attached image. The datetime makes you think it's accurate by showing a bunch of decimals, but it still has a ~1ms resolution. I think that's just a double hard at work Quote
Samapico Posted September 1, 2011 Report Posted September 1, 2011 I don't think a double would have problems with these decimals, but the date/time might be using singles internally... But yeah Quote
Mellroth Posted September 1, 2011 Report Posted September 1, 2011 On 9/1/2011 at 12:47 PM, Mark Balla said: I am curious to know what NI Week session discussed this vi. My guess is that is is designed for RT targets. I'm sure it wasn't one of the RT sessions, instead I believe it was a tips and trick session with Darren. /J Quote
Popular Post rob.dye Posted July 11, 2012 Popular Post Report Posted July 11, 2012 I came here looking to see what the G experts have done wrt timing probes and found this discussion of High Resolution Relative Seconds.vi (HRRS). I am the person responsible for putting this VI in vi.lib/Utility. It calls back into a utility function I put into LV, which uses the same API that is used by the Desktop Execution Trace Toolkit. I intended it to use the highest resolution clock available on all of LabVIEW's supported platforms. On Windows this means QueryPerformanceCounter, which, in modern versions of Windows, takes into account multi-core/processor issues as well as variations in clock rate due to power management. (Up to date and authoritative docs on this are hard to find, but from the googling I've done, I believe my claim is correct.) This I discuss some of the behavior of HRRS at this site at ni.com: https://decibel.ni.com/content/blogs/EvanP/2010/10/04/tick-count-us--microsecond-timing-granularity-on-windows (I notice some of the picture links are busted there - I'll try to fix them.) As some of you noted, the Wait (ms) primitive is the inaccurate/inconsistent culprit in the Mr. Balla's benchmark. It uses a less accurate clock API, but one that uses the same clock as the "Get Date/Time in Seconds" and "Tick Count (ms)" primitives. Rob Dye LabVIEW R&D 8 Quote
Darren Posted July 12, 2012 Report Posted July 12, 2012 I didn't realize you were the one who added that VI, Rob. I've recommended it in multple performance presentations over the past couple of years, and your comments here and on the ni.com thread give me some extra details to include the next time I discuss it. Thanks! Quote
MikaelH Posted July 12, 2012 Author Report Posted July 12, 2012 On 7/11/2012 at 11:53 PM, rob.dye said: High Resolution Relative Seconds.vi (HRRS). I am the person responsible for putting this VI in vi.lib/Utility. Thanks for that VI, I love it. I even made my own Wait (us), VI with that and it works great. 2 Quote
asbo Posted July 12, 2012 Report Posted July 12, 2012 On 7/12/2012 at 10:47 AM, MikaelH said: Thanks for that VI, I love it. I even made my own Wait (us), VI with that and it works great. That's awesome. So, when will something like that be shipping with LabVIEW? 1 Quote
ShaunR Posted July 12, 2012 Report Posted July 12, 2012 It's a shame that the conditional disable structure cannot tell what version of LabVIEW it is. I've got a "Tick Count" vi that uses the perf counter method on windows, the normal (1ms) one on the others and it would be great if I could put another case in there to use this little gem for when I'm working in 2010 and greater so it uses the best available (I have to work in 2009,10 and 11). 1 Quote
Stagg54 Posted August 9, 2012 Report Posted August 9, 2012 On 7/12/2012 at 1:37 PM, ShaunR said: It's a shame that the conditional disable structure cannot tell what version of LabVIEW it is. I've got a "Tick Count" vi that uses the perf counter method on windows, the normal (1ms) one on the others and it would be great if I could put another case in there to use this little gem for when I'm working in 2010 and greater so it uses the best available (I have to work in 2009,10 and 11). Sounds like something for the idea exchange. Quote
pravinspidy Posted November 7, 2012 Report Posted November 7, 2012 On 8/30/2011 at 11:09 PM, MikaelH said: Hi guys How do you measure execution times/performance? I have 3 favourites. The Profiler (Profile Performance and Memory) Desktop Execution Trace toolkit (it give um timing accuracy very nice ) And a Timing Probe (see attached VIs) How do you do it? Timing Probe (Error).vi TimingProbe_Kernel.vi Cheers, Mike informative !!!! thanks Quote
