KWaris Posted July 14, 2012 Report Share Posted July 14, 2012 Hello there I have been scratching my head all day thinking if its possible to trigger an event when vi is aborted using the Abort vi button on the toolbar. Couldn't really figure out what to do. Found abort vi method but it just aborts the vi if the part of the code containing this method is executed. Any ideas? Kind Regards Austin Quote Link to comment
Yair Posted July 15, 2012 Report Share Posted July 15, 2012 The answer is that you can't. The abort button is supposed to stop the VI immediately, without giving you the chance to execute more code and is only supposed to be used in simple throwaway VIs or when debugging. It's not meant to be part of a normal UI or VI execution. If it's really important to you, you could create your own abort button and call the abort method when you get the event for it, but there is nothing guaranteeing that your code will not be stuck and unable to execute the event. Quote Link to comment
BigAngryHillMan Posted July 15, 2012 Report Share Posted July 15, 2012 It rather depends what you want to happen when you press the abort button. I have used the following method to do hardware shut-down after the abort button is pressed during debug. Simply stated you launch a watchdog VI that waits on a queue when you press the abort button on the main VI this makes the queue invalid so that the error causes the loop to end and any code following the loop to be executed. See the example attached. Example.zip 2 Quote Link to comment
Aristos Queue Posted July 15, 2012 Report Share Posted July 15, 2012 You could build a polling loop that checks whether a VI is still running and then generates an event. Quote Link to comment
Ton Plomp Posted July 16, 2012 Report Share Posted July 16, 2012 You could use an XControl and monitor the 'Execution State Changed' event. Ton Quote Link to comment
Aristos Queue Posted July 16, 2012 Report Share Posted July 16, 2012 You could use an XControl and monitor the 'Execution State Changed' event. Hm... I was thinking in terms of monitoring any arbitrary VI, but this is an interesting approach. An XControl gets an event when the owning VI changes state, so if you put an XControl on the front panel of the VI you're interested in, that XControl could fire an event when the owning VI changes state. That avoids the overhead of polling.The downside is that the XControl is going to force the front panel of the VI to always be in memory, which creates a performance hit when calling the VI since time is spent updating the front panel. If the VI you're interested in is one that has its front panel visible, this is a good idea. You would create a user event in your monitor VI, pass that user event to the VI-of-interest, which would put that user event refnum into the XControl (probably through the FPTerminal). Then when the XControl gets the "owner went idle", it fires that user event. Quote Link to comment
Darin Posted July 16, 2012 Report Share Posted July 16, 2012 (edited) Many moons ago I posted a silly VI on the dark side to post a message when a user hit the pause button. It used an XControl to monitor the Is VI Paused property (private). http://forums.ni.com/t5/LabVIEW/Is-there-a-way-to-know-programatically-when-LabVIEW-has-been/m-p/1320065#M540168 In this case, however, if your VI is in Run mode before execution then I do not believe you will receive the desired State Change Events when it is stopped. To be safe you would have to poll the execution state of the owning VI, probably inside the Facade Timeout case. I wouldn't let this anywhere near code that I cared about, but perhaps desperate times call for desperate measures. Edited July 16, 2012 by Darin Quote Link to comment
ShaunR Posted July 16, 2012 Report Share Posted July 16, 2012 The abort button is supposed to stop the VI immediately, It used to. Now you have to wait for LV to finish scratching its arse (yeah I'm looking at you serial port VIs) 2 Quote Link to comment
Ton Plomp Posted July 17, 2012 Report Share Posted July 17, 2012 A simple test shows that an XControl gets the 'Execution state change' event when the owning VI is aborted using <ctrl-.> or the 'Abort VI' method. Ton Quote Link to comment
Darin Posted July 17, 2012 Report Share Posted July 17, 2012 A simple test shows that an XControl gets the 'Execution state change' event when the owning VI is aborted using <ctrl-.> or the 'Abort VI' method. Ton Even with the VI in run mode before running? Never tried it but I thought it was run/edit mode changing. Quote Link to comment
asbo Posted July 17, 2012 Report Share Posted July 17, 2012 It used to. Now you have to wait for LV to finish scratching its arse (yeah I'm looking at you serial port VIs) Sometimes I dream about a world where LV could abort CLNs. Quote Link to comment
ShaunR Posted July 17, 2012 Report Share Posted July 17, 2012 Sometimes I dream about a world where LV could abort CLNs. I maybe just remembering through rose tinted spectacles, but I believe LV 7 could Quote Link to comment
Aristos Queue Posted July 18, 2012 Report Share Posted July 18, 2012 No, CLNs were never abortable. Once you're out of LV's execution system, there's nothing LV can do but wait for the code to return control to us. Quote Link to comment
Rolf Kalbermatter Posted July 25, 2012 Report Share Posted July 25, 2012 Sometimes I dream about a world where LV could abort CLNs. I maybe just remembering through rose tinted spectacles, but I believe LV 7 could No, CLNs were never abortable. Once you're out of LV's execution system, there's nothing LV can do but wait for the code to return control to us. Actually since about LabVIEW 8.2 they sort of are through the badly named Callback functions. LabVIEW 7 didn't have that but CINS had a CINAbort function that could do that, if properly implemented. Quote Link to comment
Aristos Queue Posted July 25, 2012 Report Share Posted July 25, 2012 Actually since about LabVIEW 8.2 they sort of are through the badly named Callback functions. LabVIEW 7 didn't have that but CINS had a CINAbort function that could do that, if properly implemented. I didn't count "signal-able" as the same as abortable. Quote Link to comment
asbo Posted July 25, 2012 Report Share Posted July 25, 2012 Actually since about LabVIEW 8.2 they sort of are through the badly named Callback functions. LabVIEW 7 didn't have that but CINS had a CINAbort function that could do that, if properly implemented. I didn't count "signal-able" as the same as abortable. Right - don't those just allow you to call another function in your library? In almost every use case I've had where I wanted to abort, it's because the DLL is misbehaving/unresponsive (and naturally has no signalling routine). If LV were to fork (or CreateProcess or CreateThread or however you'd actually implement it) and then call the routine, wouldn't that be a pretty effective way to sandbox the call and make it abortable? Quote Link to comment
Rolf Kalbermatter Posted July 25, 2012 Report Share Posted July 25, 2012 Right - don't those just allow you to call another function in your library? In almost every use case I've had where I wanted to abort, it's because the DLL is misbehaving/unresponsive (and naturally has no signalling routine). If LV were to fork (or CreateProcess or CreateThread or however you'd actually implement it) and then call the routine, wouldn't that be a pretty effective way to sandbox the call and make it abortable? Well, yes they allow to call another function or more precisely three. One when the CLN is initialized, one when the VI containing the CLN is aborted and one when the CLN is unintialized. Each takes a context parameter that can also be added to the actual function call itself. So in the OnReserve function you create the context with whatever info your function might require, in the function call itself you setup some bookkeeping of some sort to be able to signal the thread to stop, and in the OnAbort you abort the thread, preferably not by killing the process but by correctly signalling whatever is waiting on some external event. OnUnreserve you deallocate and clean up whatever has accumulated during the OnReserve, OnAbort and function calls. Of course if your DLL is buggy and just hangs somewhere, this signaling won't help, but honestly once you are in there, nothing will really help safe from killing the process. LabVIEW can not even start to guess how to recover properly from such a situation since it has absolutely no control of the stack during the function call. Any attempt to resume after a forced abort is doomed to cause many nasty sideeffects, if it doesn't immediately go into pointer nirvana. And no a DLL interface doesn't specify a certain Exception handling interface at all, and Exception handling very much depends on the used compiler, since each tends to have it's own patent encumbered exception handling mechanisme. The OnAbort function is responsible to signal the waiting thread and make sure it cleanly exists back to the LabVIEW diagram with properly cleaned up stack and all. Quote Link to comment
Aristos Queue Posted July 26, 2012 Report Share Posted July 26, 2012 If LV were to fork (or CreateProcess or CreateThread or however you'd actually implement it) and then call the routine, wouldn't that be a pretty effective way to sandbox the call and make it abortable? If LV ran the call in a separate process, would it be able to share memory? I don't think it can... even if LV allocations could be shared with the process, allocations from that process could not be shared with LV because those allocations would evaporate when the process exited. That would be a pretty hefty penalty for calling libraries if all strings and arrays triggered data copy.The only real solution would be for all of LV's VIs to run in a separate process from the editor, something that other IDEs do but LV does not because historically it has introduced too many usability issues for which we did not have good solutions. Over the years, various solutions have been found, but at this point, the unity of the execution environment and the dev environment is pretty deeply built in and it would take a rewrite of a substantial part of LV to separate those. Quote Link to comment
asbo Posted July 26, 2012 Report Share Posted July 26, 2012 If LV ran the call in a separate process, would it be able to share memory? I don't think it can... even if LV allocations could be shared with the process, allocations from that process could not be shared with LV because those allocations would evaporate when the process exited. That would be a pretty hefty penalty for calling libraries if all strings and arrays triggered data copy. Urgh, excellent point. It might be possible to dance around this with memory mapping or virtual allocations (in Windows, anyway). It would be an interesting problem to try and solve, but I trust that if it hasn't been done yet, it's either not worth doing or can't be done. What you say is true, though; anything short of actually separating the IDE from the debugger/RTE/whatever is just a bandage. It would be really cool if we could do that, but it doesn't surprised me that the two are so deeply intertwined at this point. Quote Link to comment
Rolf Kalbermatter Posted July 26, 2012 Report Share Posted July 26, 2012 If LV ran the call in a separate process, would it be able to share memory? I don't think it can... even if LV allocations could be shared with the process, allocations from that process could not be shared with LV because those allocations would evaporate when the process exited. That would be a pretty hefty penalty for calling libraries if all strings and arrays triggered data copy. The only real solution would be for all of LV's VIs to run in a separate process from the editor, something that other IDEs do but LV does not because historically it has introduced too many usability issues for which we did not have good solutions. Over the years, various solutions have been found, but at this point, the unity of the execution environment and the dev environment is pretty deeply built in and it would take a rewrite of a substantial part of LV to separate those. And in practice LabVIEW has already the seperation of runtime system and IDE, or otherwise remote target deployment and debugging both with RT and FPGA targets as well as from desktop LabVIEW to desktop LabVIEW would not be possible. But it's not the solution for allowing truely abortable CLNs. You would have to separate the actual CLN context in order to be able to recover from an aborted CLN and that would mean an isolation of parts of the runtime system inside the runtime system. A pain in the ass to do, and a total performance killer as you have already aluded to about string and array parameters that would trigger copies. Quote Link to comment
