Neil Pate
Set a default path when clicking path browse
Does anybody know if it is possible to configure the path control so that when a user clicks the browse button the file dialogue that pops up has a custom filename pre-populated? You can do this easily with the dialogue prim, but I cannot figure out how to do this with the path control. I thought perhaps there would be an event that is fired off on browse, but it does not appear so.
I suppose I could hide the browse button and replace it with a regular button...
Share this post
Link to post
Share on other sites
I don't think there's a way to do it. You'll need to make your own browse button.
Share this post
Link to post
Can't you use property node=>Path Text=>Scroll Position instead?
Share this post
Link to post
Just set the default value of the control.
Does this work at runtime in an exe? I never thought to try this, thanks for the suggestion.
The problem is I need to set the default value as soon as the browse button is pressed, not before. There is no event exposed that will trigger when the browse button is clicked.
Edited by Neil Pate
Share this post
Link to post
You can try the mouse down event, then set the match pattern and start path. That fires before the browse window appears.
Edited by Gribo
Share this post
Link to post
But mouse down fires off when the user clicks anywhere in the path, I am after just the browse button.
I ended up replacing the button with my own one and it all works ok, just a bit of a bodge.
Share this post
Link to post
The next easiest alternative is to find the browse button's coordinates.
Share this post
Link to post
Yup, and now we are way too deep in the rabbit hole. A standard boolean does pretty much exactly what I need it just does not have an icon on it.
As soon a NI open sources LabVIEW we will be able to fix things like this 🙂
Share this post
Link to post
Well. You could make an XControl.
  • Haha 1
  • Sad 1
Share this post
Link to post
This works, but it uses a private property.
I've added that property to a list I'm maintaining of private properties/methods/events to move to public/scripting in a future LabVIEW release.
Share this post
Link to post
And then I have two problems...
If that scares you then I don't give you good odds on "fixing" the LabVIEW source when it's released :D
I've just written two XControls. (First time in about 6 years). They seem to be ok but some of the ways they work can be a bit unintuitive.
Share this post
Link to post
Coincidentally I just wrote a couple as well. I agree they seem OK for simple things, but the whole question of when and how they wake up makes them less usable. The main reason I want an Xcontrol is that a lot of things are combined controls+indicators. For example I have an indicator with the current value and the setpoint and some other stuff, and a control for the setpoint -- but you can't bind to user events, so you have to pick a proper 'direction' for the control and use a property for the other way and you end up having to marshal data around anyway. I don't hate them as much as I once did, but I don't like them.
I think the q guy had it right, basically just grouping control references together and using standard functions to manipulate the group as one: https://sine.ni.com/nips/cds/view/p/lang/en/nid/214228
Edited by smithd
Share this post
Link to post
Yeah mine were a little more obvious that an xcontrol was really the only elegant half-way decent solution. One was a string control with markup and the other was a tab control that works like the native one should. So it was really about encapsulation.
Edited by ShaunR
  • Thanks 1
Share this post
Link to post
Wow, glad I have my fireproof jacket on this morning! 🤣
Share this post
Link to post
Why would you need an Open Sourced LabVIEW for something like that? This was possible in the Control editor since LabVIEW 3!!! (Discloser: the Browse button in the Path control was not added before somewhere around version 6 to 8 but the principle worked in LabVIEW 3).
1) Place a path control on your front panel
2)  Right click on it and select Advanced->Customize  => The path control opens in the control editor
3) Right click on the browse button and select Advanced->Customize   => The browse boolean control opens in the control editor
4) Save this as your Browse Boolean.ctl file or whatever you want to call it.
5) Use as you wish and enjoy that it automatically adapts to the platform style for the system you run it on
Browse.ctl
Edited by Rolf Kalbermatter
  • Like 2
Share this post
Link to post
There must be another step or perhaps an ini-key because customise is greyed out for the browse button on my installations.
Share this post
Link to post
I thought it was not relevant when trying out things as I did various trials to get this working (The Control Editor has "particular" behaviour and controls easily can get in a weird state where for instance some of the parts end up in places where they seem not selecatable anymore in the customize mode, they still are but the position where you need to click to select them doesn't match the position on the front panel where they really appear.)
2)  Right click on it and select Advanced->Customize (or double click) => The path control opens in the control editor
2.5) Change to Customize mode (click on the Allen key which then changes to a pincer)
3) Right click on the browse button and select Advanced->Customize  Double click on the Browse button => The browse boolean control opens in the control editor
For step 2) double click and step 3) you might need to have the option enabled to open the custom control editor on double click, which is one of the first things I always enable when installing a new LabVIEW version, right after disabling auto tool and auto wire routing 🤢.
Share this post
Link to post
