Linux cRIO Memory Usage
Neil Pate
As per this KB it is no longer possible to retrieve the memory usage using the System Session property nodes. Considering the Linux implementation is several years old already this seems like quite an oversight but not something NI seems terribly worried about. The solution proposed in the KB seems quite incomplete.
Strangely, NI do have a way to get this info as it is reported in MAX
Does anyone have a solution for this?
29 minutes ago, ensegre said:
spitballing, having never worked on cRIO: standard linux ways like just parsing the output of free wouldn't help? Or reading /proc/meminfo?
Yeah it seems this is the way to go, I was just hoping somebody had done this already 🙄
I have tested both using an SSH console into a cRIO VM and they do seem to work.
Edited by Neil Pate
  • 2 weeks later...
Permissions might prevent the reading of the file.  If you do a Open File maybe even set to read only then read the file you might have better luck.  Also calling a system exec and reading the standard output might work as well.
1 hour ago, Neil Pate said:
The confusing thing is the file read does work, but only if I read it as lines instead of characters.
I don't have a linux machine handy, right now, but try unchecking the "Convert EOL".
Tried that, no dice. The file read returns an empty string.
OK. Got hold of my Linux Box with LabVIEW. Wire a number of bytes to the "Count" (1024?). Ignore the error 4 if you demand too many.
  • Like 2
Oh yeah, just wire a -1 and you get the whole file.  I always forget that.
Tried that in my original test, still did not work.
Edited by Neil Pate
That doesn't work. I would say it is a bug but it's never worked. ¯\_(ツ)_/¯.
This is what I have on my Linux box (not a cRIO though) so if you don't get anything; that is definitely a bug.
Okay I'm done guessing without actual testing in the environment.  In Windows -1 on the Read From Text File, and Read From Binary File both read the whole file.  I feel like there is a bug or two found in this thread.
Given that it's not an actual file perhaps it has no idea of how much to read without parsing the lines in the primitive? There is no "size" information but if it reads as lines it keeps going until the end using read operations. Regardless -1 does not work on my 9046.
If you read a text file then it will work. However. as Jordan states; it is not an actual file. It's is a text output stream from the VFS.
Most likely when you pass in -1, it does a stat() (or possible the equivalent of the internal FSGetSize() function) to determine the size of the "file" and read that much bytes. Since it is a VFS it can't return a valid size for the "file" (most likely fills in 0) and LabVIEW concludes that it is an empty file and returns that.
