Thang Nguyen Posted December 2, 2021 Report Posted December 2, 2021 (edited) Our company used NI RT controller CVS-1459 RT. Without any information, they discontinued this controller and suggest us about IC-3121. And we just found out it will discontinue the end of this year. All of this happen in one year. I contacted NI for replacement product and they suggest IC-3120 which has 2 ethernet ports instead of 2 USB 3.0 which we use to connect our cameras. NI engineer then suggest IC-3171 which is $1,700 higher than IC-3121 which is $3,000. What I am worry is we don't have any information ahead. I work with LabVIEW for 15 years. I used to have connection with NI sell representative. Now I don't have any information about the product timeline at all. I contacted with NI sale and they are now Newark company and they cannot answer me about controller replacement. What should I do in this case? Is there any person in NI should I contact with? Edited December 2, 2021 by Thang Nguyen Quote
Tim_S Posted December 2, 2021 Report Posted December 2, 2021 (edited) NI has published their hardware lifecycle policy. When you look up each of the controllers you can see what the current lifecycle status is. Below is a search for the part number on NI's website. Edited December 2, 2021 by Tim_S Quote
Antoine Chalons Posted December 3, 2021 Report Posted December 3, 2021 I understand your concern, NI's commitment to industrial vision has always been a bit loose I think. RT vision controllers come and go a bit fast. And there was the fiasco of the EVS, whose long term replacement was the IC-31xx, but when was the last update of that line? Many years ago and there's no communication around the future of this product. My advice is to find a different hardware supplier for "vision industrial computer" and use Windows 10 iot, otherwise NI will soon tell you to use a PXI! At some point NI was considering allowing to install NI Linux RT on non NI hardware, but I seriously doubt they'll ever to that, it would be in huge contradiction with their business model. Quote
Jordan Kuehn Posted December 3, 2021 Report Posted December 3, 2021 8 hours ago, Antoine Chalons said: At some point NI was considering allowing to install NI Linux RT on non NI hardware, but I seriously doubt they'll ever to that, it would be in huge contradiction with their business model. If they do not do this they need to beef up their offerings. Right now the 9047 is the most powerful cRIO platform (-40C) and we are reaching limitations with it, but the only more powerful platform is a PXI controller. Lettings us put Linux RT on hardware we source would also help with the current lead times that are stretching out past 6 months for some of this hardware. Quote
Antoine Chalons Posted December 3, 2021 Report Posted December 3, 2021 Indeed the IC line of product was supposed to stand between the cRIO and PXI in term of perf - without offering the modularity that cRIO and PXI offer of course, but for Vision application it was ok with usb3 and GigE. But even then, the perf was disappointing for heavy vision application. I use to use Advantech IPC range, updated every 6 month with new CPUs etc. Supporting 3rd party hardware with NI Linux RT would probably require a huge effort for NI, not sure they're ready for that. And where NI is disappointing me a bit more is by not telling us what their plan is for Hardware between cRIO and PXI, at least if they were to say they are only going to maintain cRIO and PXI in the future at least we'd stop hopping a find a different solution. Quote
Jordan Kuehn Posted December 3, 2021 Report Posted December 3, 2021 10 minutes ago, Antoine Chalons said: Indeed the IC line of product was supposed to stand between the cRIO and PXI in term of perf - without offering the modularity that cRIO and PXI offer of course, but for Vision application it was ok with usb3 and GigE. But even then, the perf was disappointing for heavy vision application. I use to use Advantech IPC range, updated every 6 month with new CPUs etc. Supporting 3rd party hardware with NI Linux RT would probably require a huge effort for NI, not sure they're ready for that. And where NI is disappointing me a bit more is by not telling us what their plan is for Hardware between cRIO and PXI, at least if they were to say they are only going to maintain cRIO and PXI in the future at least we'd stop hopping a find a different solution. I agree with all of this. Quote
Thang Nguyen Posted December 3, 2021 Author Report Posted December 3, 2021 (edited) Thanks @Tim_S for the lifecycle page Thanks @Antoine Chalons and @Jordan Kuehn for sharing expert knowledge about vision controller. @Antoine Chalons May I ask if Advantech IPC with Win 10 iot is a good option? Currently, we use only one camera for processing but we plan to update to dual cameras very soon. Can I use LabVIEW with Win 10 iot? Edited December 3, 2021 by Thang Nguyen Quote
Antoine Chalons Posted December 3, 2021 Report Posted December 3, 2021 Well "good option" is a bit broad... it was great for my application There production line was producing 60 part par minute There were 3 C-Link camera, therefore 2 PCIe-1430 frmaegrabbers Each cam was acquiring 10 images of each part The time available for image acquisition + processing was ~800ms so the acquisition was done in parallel to the processing for each camera. At the time (3 years ago almost) we were getting the most powerfull IPC-720 available with 32Gb of RAM and Windows 10 IOT. The application did not require fanless or RT and it was working 24/7. We also had similar application with GigE cameras but I never liked GigE. Quote
Thang Nguyen Posted December 3, 2021 Author Report Posted December 3, 2021 @Antoine Chalons Can I run LabVIEW on Windows Iot? Do you know any limitation? May I ask why do you switch to NI controller since you said you used to use Advantech IPC? Quote
Antoine Chalons Posted December 3, 2021 Report Posted December 3, 2021 Never had any issue with LabVIEW on windows 10 iot I changed job 3 years ago, I don't do vision anymore, that's why I said I used to use Advantech, I never had problems with IPC-720. 1 Quote
Thang Nguyen Posted December 3, 2021 Author Report Posted December 3, 2021 @Antoine Chalons Thank you very much! Your information is very value to me. Quote
Rolf Kalbermatter Posted December 5, 2021 Report Posted December 5, 2021 (edited) On 12/3/2021 at 4:19 PM, Thang Nguyen said: Can I use LabVIEW with Win 10 iot? It depends what Windows IoT you are wanting to use. There are 2 different versions I believe. - IoT Core, only supports UWP applications, no Win32 applications. Also used on ARM platforms. LabVIEW as a x86/64 Win32 application can NOT run on this at all, independent if you try the IDE or built EXEs. - IoT Enterprise, full Windows platform with streamlined distribution and settings, only available for x86/64 hardware, LabVIEW applications can run on this Edited December 5, 2021 by Rolf Kalbermatter Quote
Antoine Chalons Posted December 5, 2021 Report Posted December 5, 2021 Indeed, Advantech offers Win 10 IoT Enterprise. If you take a look at this product : https://advdownload.advantech.com/productfile/PIS/AIMB-587/file/AIMB-587_DS(082721)20210827160444.pdf This is the equivalent up-to-date version of what I was using, it does mention Win 10 IoT Ent (not sure about the difference HL and VL though. Quote
Rolf Kalbermatter Posted December 6, 2021 Report Posted December 6, 2021 (edited) 13 hours ago, Antoine Chalons said: Indeed, Advantech offers Win 10 IoT Enterprise. If you take a look at this product : https://advdownload.advantech.com/productfile/PIS/AIMB-587/file/AIMB-587_DS(082721)20210827160444.pdf This is the equivalent up-to-date version of what I was using, it does mention Win 10 IoT Ent (not sure about the difference HL and VL though. Microsoft sells three levels of Windows IoT Enterprise: Entry Level, Value Level and High Level. They supposedly have to do with the CPU performance, so I guess number of supported cores and maybe other things like hyperthreading, amount of supported memory etc. The exact details seem only available under NDA. Edited December 6, 2021 by Rolf Kalbermatter 1 Quote
Thang Nguyen Posted December 17, 2021 Author Report Posted December 17, 2021 @Antoine Chalons I am at the phase making decision on specific hardware and OS to run with so I am need to clear up on some information. After doing more research about Windows IOT, specifically Windows IOT Enterprise and Windows Enterprise, I wonder if you choose to use the Windows IOT Enterprise because it comes pre-install on the controller you want to work with? Or because it has some specific features which make you choose to use it? Quote
Antoine Chalons Posted December 17, 2021 Report Posted December 17, 2021 If I remember well, windows 10 iot was the default option with the industrial computer from Advantech, at least that's what the reseller told me. We ordered one to try (with a return option if it didn't work), we tested for a few days, we were happy. We were only interested in in having something that worked like windows 10, came pre-installed and didn't have all the media/game nonsense that comes on "normal" computers. Quote
Thang Nguyen Posted December 18, 2021 Author Report Posted December 18, 2021 Thank you very much for your answer. Quote
Rolf Kalbermatter Posted April 1, 2022 Report Posted April 1, 2022 (edited) 23 hours ago, bellagenesis1023 said: We utilise two USB 3.0 ports to link our cameras to IC-3120, which has two ethernet connectors instead of two USB 3.0 ports. Finally, an NI expert recommends IC-3171, which is $1,700 more expensive than IC-3121. What worries me is that we have no idea what to expect. One development environment for all of your hardware is possible with LabVIEW. LabVIEW communicates with your hardware using driver software, which acts as a bridge between the two. Using LabVIEW driver software, various instruments, buses, and sensors may be seamlessly integrated. I have a list of 9 Best Motherboard For Ryzen 5 3600 – Best Budget Machines of 2021-22 Is that spam to advertise a link or do you have a specific question? Edited April 1, 2022 by Rolf Kalbermatter Quote
ensegre Posted April 1, 2022 Report Posted April 1, 2022 (edited) On 12/2/2021 at 5:04 PM, Thang Nguyen said: I contacted NI for replacement product and they suggest IC-3120 which has 2 ethernet ports instead of 2 USB 3.0 which we use to connect our cameras. NI engineer then suggest IC-3171 which is $1,700 higher than IC-3121 which is $3,000. What I am worry is we don't have any information ahead. It's spam, as it copied sentences from the first post of Thang in this thread. However, with some syntactic changes .... I wonder if that is AI or a literate poor spam factory worker. Edited April 1, 2022 by ensegre Quote
hooovahh Posted April 1, 2022 Report Posted April 1, 2022 See I didn't think it was spam right away since they didn't have a link so I flagged it as something to look at later to see if they put a link in the message later. Sure enough they did. Quote
