John Lokanis Posted August 8, 2009 Report Posted August 8, 2009 Many of the presenters at NI Week promoted the LabVIEW Idea Exchange here. I have been reading, voting and posting to the idea exchange for awhile and just posted several new ideas/complaints that I thought of while attending NI Week. I challenge all LAVA members to visit the exchange and vote for the ideas you agree with (especially mine ). And if you don't agree, post a comment and tell me why! Then post your own ideas so we can all vote of them too. The more feedback we give, the better LabVIEW will be in the future. -John Quote
Yair Posted August 9, 2009 Report Posted August 9, 2009 Quote vote for the ideas you agree with (especially mine ) I think what you meant to say was especially mine. Quote
Daklu Posted August 10, 2009 Report Posted August 10, 2009 Well heck, if we all vote for each other's ideas all our ideas will float to the top and LAVA will be defining the future of Labview. Quote
Yianni29 Posted September 9, 2009 Report Posted September 9, 2009 John Lokanis, which is your idea? Can you provide us with a direct link? My idea is for True .NET Support http://forums.ni.com/t5/LabVIEW-Idea-Exchange/True-NET-Support/idi-p/977884#A2106 I basically think that NI should spend some more time and effort making LabVIEW inter operate with other programming languages and technologies better because I hope to use LabVIEW to co-develop applications already written in other languages! Quote
John Lokanis Posted September 9, 2009 Author Report Posted September 9, 2009 On 9/9/2009 at 4:59 PM, Yianni29 said: John Lokanis, which is your idea? Can you provide us with a direct link? Look for all ideas by 'jlokanis'. I have posted several. I liked your .NET idea! Kudos! Quote
Michael Aivaliotis Posted October 10, 2009 Report Posted October 10, 2009 Please vote for my Idea: Add an "Explain Error" pop-up menu on the conditional error probe Quote
John Lokanis Posted February 4, 2010 Author Report Posted February 4, 2010 Here is a new idea I just posted. Please take a look and Kudo it if you agree! http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Find-needs-to-have-multiple-search-criteria-with-logic/idi-p/1066409#A4046 Quote
Antoine Chalons Posted February 12, 2010 Report Posted February 12, 2010 Hi all, /Advertising mode=on I've posted a few ideas on the LabVIEW Idea Exchange if you think they're worth, please vote - "Open Private Callees" and "Open Public Callees" options from the project window - "Open all Callers" option from the project window - More exclusion settings for the VI Hierarchy - Bad wire gets cleared automatically when it can (when you re-wire, the bad part is removed) /Advertising mode=off 1 Quote
gb119 Posted February 13, 2010 Report Posted February 13, 2010 <advert> Volatile state for XControls </advert> Quote
crelf Posted February 14, 2010 Report Posted February 14, 2010 Add a VI Heirachy Button to Filter out Reuse Components. Quote
Yair Posted February 14, 2010 Report Posted February 14, 2010 Here are all 16 ideas I posted. Obviously, all of them are brilliant, so you should go vote for them (although some, and I won't say which, will already probably be in LV 2010, so no need to vote for those). Quote
Ton Plomp Posted February 17, 2010 Report Posted February 17, 2010 Here are my ideas (all but one super fantastic). And my latest: Add drag and drop support for OS files on any control. I wonder why this hasn't been requested before or implemented before. Ton Quote
jgcode Posted February 26, 2010 Report Posted February 26, 2010 I would like to be able to have hooks into the Dynamic Dispatch and Static Dispatch templates, just like we got for data member access http://forums.ni.com/t5/LabVIEW-Idea-Exchange/LVOOP-Custom-User-Dynamic-Dispatch-and-Static-Dispatch-Hooks/idi-p/1029957 Quote
Ton Plomp Posted April 5, 2010 Report Posted April 5, 2010 Anyone seen the Data Acquisition idea exchange? I like the idea for a DAQmx simulation API. Ton Quote
GregSands Posted April 16, 2010 Report Posted April 16, 2010 Two new ideas: 1) Change the configuration of parallel loops 2) Allow multi-dimensional arrays to be reshaped to 1D arrays using the In Place Element Structure Quote
John Lokanis Posted June 11, 2010 Author Report Posted June 11, 2010 Please look at this idea regarding creating sub vis from a selection: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Create-SUB-VI-from-selection-should-intelligently-inherit/idc-p/1146804#M5955 thanks! -John Quote
jgcode Posted June 17, 2010 Report Posted June 17, 2010 Here are two ideas I have had with respect to X-Controls: X-Control Display Icon (so an .xctl looks good in the Palettes) Show X-Control in User.lib Auto Generated Controls Palette Quote
asbo Posted June 17, 2010 Report Posted June 17, 2010 Horizontal Scroll Hotkey Enable 'Retain Wire Values' for entire VI hierarchy Quote
jgcode Posted June 17, 2010 Report Posted June 17, 2010 Display Qualified Name in Inheritance Dialog Box for LabVIEW Classes Quote
jgcode Posted June 17, 2010 Report Posted June 17, 2010 Allow X-Control/X-Control Reference as a Class Data Member Quote
dannyt Posted June 18, 2010 Report Posted June 18, 2010 Simple idea that would help me Close Other VI's Quote
Antoine Chalons Posted June 23, 2010 Report Posted June 23, 2010 For those who use scripting, you might want to support these 2 ideas : Expose "Replace With" LabVIEW Project Method via VI Server Expose all available LabVIEW Project Methods via VI-Server 1 Quote
jgcode Posted June 25, 2010 Report Posted June 25, 2010 Sending Packages (.ogp, .vip, .vipc files) to NI Support is an acceptable way to submit code Quote
jgcode Posted June 29, 2010 Report Posted June 29, 2010 Option to Add LabVIEW Project Library To Parent Library and Set Scope in Source Distribution Build Spec Quote
