SuperS_5 Posted December 18, 2010 Report Share Posted December 18, 2010 I think the list of things that we DON'T like is a whole lot shorter, and probably easier to run though. What we do like will go on, and on, and on.... <now where is that energizer bunny> Quote Link to comment
jgcode Posted December 18, 2010 Report Share Posted December 18, 2010 LabVIEW's ability to be extended. There is nothing I like more then creating reuse code and have it appearing in the palettes or writing tools that I can access natively. Quote Link to comment
ShaunR Posted December 19, 2010 Report Share Posted December 19, 2010 "Create Sub-vi" function. Saves hours if time when prototyping by allowing hierarchy realisation, easy modularisation and, of course, cleaning up diagrams. All in one step . Imagine what you would have to go through if you wanted to replace some code with a sub-vi if we didn't have it Quote Link to comment
Ton Plomp Posted December 20, 2010 Report Share Posted December 20, 2010 This is quite interesting. January first 2011 a poll will be started that includes the input from this thread to decide what the best design feature of LabVIEW is. If you have any ideas left, please post them! Ton Quote Link to comment
Grampa_of_Oliva_n_Eden Posted December 20, 2010 Report Share Posted December 20, 2010 (edited) Nobody has mentioned the obvious feature... Data Flow By using graphical represenations of opeartions, typos* and syntax errors are eliminated. Memory management No need to check limit malloc and debug access violations. For those cases where the memory allocations are not obvious LV includes "Show Buffer Allocations" to let us SEE where the buffers are located. Ben * anyone that has read more than one of posts should understand why I really apprecaite the lack of syntax. Edited December 20, 2010 by neBulus 1 Quote Link to comment
Black Pearl Posted December 20, 2010 Report Share Posted December 20, 2010 Nobody has mentioned the obvious feature... Data Flow By using graphical represenations of opeartions, typos* and syntax errors are eliminated. Check my post (it's #3). But I didn't supply an argument for it. Felix 1 Quote Link to comment
Grampa_of_Oliva_n_Eden Posted December 20, 2010 Report Share Posted December 20, 2010 Check my post (it's #3). But I didn't supply an argument for it. Felix Well I stand corrected (again). Two Kudos for you, one for the original post and one for pointing at it. Ben Quote Link to comment
Cat Posted December 30, 2010 Report Share Posted December 30, 2010 Updo^H^H^H^H Fondu Undo! Yes, that's it! I still remember the fuss some members of the LV user community made over LV developers "wasting their time" implementing undo... 1 Quote Link to comment
ShaunR Posted December 30, 2010 Report Share Posted December 30, 2010 (edited) Updo^H^H^H^H Fondu Undo! Yes, that's it! I still remember the fuss some members of the LV user community made over LV developers "wasting their time" implementing undo... Ooooh. Yes! and that reminds me of "PERVERT" "REVERT". For those "dead end" moments when you've been owned by the spaghetti Edited December 30, 2010 by ShaunR Quote Link to comment
Cat Posted December 30, 2010 Report Share Posted December 30, 2010 For those "dead end" moments when you've been owned by the spaghetti It helps if you have embraced the Noodly Appendages of the Flying Spaghetti Monster. 2 Quote Link to comment
ShaunR Posted December 30, 2010 Report Share Posted December 30, 2010 It helps if you have embraced the Noodly Appendages of the Flying Spaghetti Monster. I'm not sure I ant to know what appendages you've embraced. ... Noodly or otherwise Although I'm willing to be converted if the "Halloween Missionaries" want to save me Quote Link to comment
Cat Posted December 30, 2010 Report Share Posted December 30, 2010 I wish to change my answer, now that LV2010 takes about 4 times more time to compile my application it became my favorite feature, and this is why. Ack! I hate it when one of you guyze posts a link to that website! I get absolutely nothing done afterward! Quote Link to comment
asbo Posted December 30, 2010 Report Share Posted December 30, 2010 Updo^H^H^H^H It took me a whole second to figure out what was going on here. Thank you for that. Quote Link to comment
Erik Disler Posted February 14, 2013 Report Share Posted February 14, 2013 If I have to vote for a best LV design feature, first of course is the graphical / dataflow model. Then the ease of hyperthreading / multicore processing. Another key feature wasn't mentioned, but, of course, is indispensable; The rich collection of libraries for science and engineering applications. 1 Quote Link to comment
Rolf Kalbermatter Posted February 17, 2013 Report Share Posted February 17, 2013 Self-indexing for loops.Beats ANY other language hands down as they don't have an equivalent.and have to put length checks all over the place and usually get it wrong . Actually that is not entirely true. If you have an iterable object in Java or .Net you can write somewhat more tense code. Java uses: for (<type> obj : objList) and .Net has a special keyword foreach (<type> obj in objList) Quote Link to comment
Cat Posted February 17, 2013 Report Share Posted February 17, 2013 Actually that is not entirely true. If you have an iterable object in Java or .Net you can write somewhat more tense code. I read this as: "If you have an irritable object ... you can write somewhat more tense code." 1 Quote Link to comment
Gribo Posted December 8, 2013 Report Share Posted December 8, 2013 The diagram clean up button. No one else will have a 'Make code look nice' button. I wish I had it in other parts of my life... Quote Link to comment
Rolf Kalbermatter Posted December 9, 2013 Report Share Posted December 9, 2013 The diagram clean up button. No one else will have a 'Make code look nice' button. I wish I had it in other parts of my life... Actually most modern text code IDEs have nowadays auto-intend with configurable code style rules so there certainly exists a "make code look nice" function there, although it is usually a menu and not a button. Quote Link to comment
Sparkette Posted April 21, 2021 Report Share Posted April 21, 2021 (edited) 3 votes for XControls; seems legit EDIT: Oh wow, 7 years since a reply to this thread? I guess that doesn't matter since it's a sticky post though. Edited April 21, 2021 by flarn2006 Quote Link to comment
hooovahh Posted April 22, 2021 Report Share Posted April 22, 2021 Good discussions are timeless. There's lots of great content on LAVA that goes dormant, but its still there. I would almost put XControls in the best features, and worst features list personally. I still stand by my debugging comment from almost 11 years ago. Quote Link to comment
