george seifert Posted February 9, 2011 Report Share Posted February 9, 2011 I'm using LV2010 on Windows XP (although I saw the same thing with LV2009). It takes at least 10 seconds after I drop a VI (and other things too) on my diagram before I can do anything else in LV. Is there some setting that will fix that. Is it maybe recompling every time? This is getting really old. George Quote Link to comment
bmoyer Posted February 9, 2011 Report Share Posted February 9, 2011 I'm using LV2010 on Windows XP (although I saw the same thing with LV2009). It takes at least 10 seconds after I drop a VI (and other things too) on my diagram before I can do anything else in LV. Is there some setting that will fix that. Is it maybe recompling every time? This is getting really old. George I gave up on LV2010. Tried converting a large LV8.5 project to LV10 and it was so slow it was unusable! Saving a VI after a simple change usually took about 30 seconds. I even tried turning off the separate compile files option but still pretty bad. I managed to create the exe of the project and it seems to take a lot longer to load even though it's supposed to execute up to 20% faster. I had to go back to 8.5 after wasting a lot of time due to time constraints. Bruce Quote Link to comment
mje Posted February 9, 2011 Report Share Posted February 9, 2011 I'm using LV2010 on Windows XP (although I saw the same thing with LV2009). It takes at least 10 seconds after I drop a VI (and other things too) on my diagram before I can do anything else in LV. Same thing happens to me, though only for a fraction of a second. I'll drop something, wire nodes, or generally do anything that affects code and the IDE will hang for maybe 100 ms. My guess it's recompiling? Irritating. Happens on all three of my development systems, both in XP and Win7. Quote Link to comment
Grampa_of_Oliva_n_Eden Posted February 9, 2011 Report Share Posted February 9, 2011 My little time with LV 10 under XP did NOT show any delays. I don't have auto-save turned on. Mybe I just didn't notice the delay or maybe the VI wasn't large enough. Ben Quote Link to comment
jgcode Posted February 9, 2011 Report Share Posted February 9, 2011 I have been working in 2010 for the last two months, but full time as of late. In the IDE I have not noticed a slow down when things do edit-time compiles. But I am using a 3GHz i7 with SSD so I may be biased. I have seen terrible IDE performance in 2009 (launching, opening dialogs - esp app installer) that was made faster by re-imaging PC. OOI: AQ told me last year that NI have found the location of the installation on the HDD can affect performance and had an active test rig setup for this. I have had more dramas with edit-time compiling on FPGA. But again I have heard that NI have been working on this too Quote Link to comment
jzoller Posted February 9, 2011 Report Share Posted February 9, 2011 Just curious... are you using the separate compiled code option? (VI Properties->General checkbox) Quote Link to comment
jdunham Posted February 9, 2011 Report Share Posted February 9, 2011 I gave up on LV2010. Tried converting a large LV8.5 project to LV10 and it was so slow it was unusable! Saving a VI after a simple change usually took about 30 seconds. I even tried turning off the separate compile files option but still pretty bad. I managed to create the exe of the project and it seems to take a lot longer to load even though it's supposed to execute up to 20% faster. I had to go back to 8.5 after wasting a lot of time due to time constraints. Bruce I have noticed that if I do a Find operation in the LabVIEW Project, and the project is large, then any change makes LabVIEW unresponsive for 30-120 seconds, and the Z-order of the open windows is shuffled around. This does not include "Find and Replace" (ctrl-F in a VI) or "Find All Instances (right-clicking on an icon) but does include "Find in Project" (Crtl-F in an open project) or "This VI in Project" (Ctrl-shift-E) in a VI. If I close LV and reopen it, the problem goes away until I use the Find function again (which I have learned not to do). It does not always happen, but if many windows are open, it is more likely to occur. I don't have a CAR # for this, because I can't always reproduce it. Bruce, does this match anything you experienced? Quote Link to comment
MikaelH Posted February 9, 2011 Report Share Posted February 9, 2011 I'm using LV2010 on Windows XP (although I saw the same thing with LV2009). It takes at least 10 seconds after I drop a VI (and other things too) on my diagram before I can do anything else in LV. Is there some setting that will fix that. Is it maybe recompling every time? This is getting really old. George George, Are you having the Project Window opened? If so, try to open the VI direct without the project, does this speed up the performace? There was a bug NI fixed in 2010 to solve this, but I'm not sure it solved all Slow Editing issues. Cheers, Mikael Quote Link to comment
ShaunR Posted February 10, 2011 Report Share Posted February 10, 2011 I'm using LV2010 on Windows XP (although I saw the same thing with LV2009). It takes at least 10 seconds after I drop a VI (and other things too) on my diagram before I can do anything else in LV. Is there some setting that will fix that. Is it maybe recompling every time? This is getting really old. George I found a mass compile of the Labview directory sorted out most of this problem in 2009 and, generally, the 32bit to be a complete slug compared to the 64 bit - on a 64 bit machine. Mass compile doesn't do anything for 2010. It's still a slug on valium. Quote Link to comment
dannyt Posted February 10, 2011 Report Share Posted February 10, 2011 I have noticed that if I do a Find operation in the LabVIEW Project, and the project is large, then any change makes LabVIEW unresponsive for 30-120 seconds, and the Z-order of the open windows is shuffled around. This does not include "Find and Replace" (ctrl-F in a VI) or "Find All Instances (right-clicking on an icon) but does include "Find in Project" (Crtl-F in an open project) or "This VI in Project" (Ctrl-shift-E) in a VI. If I close LV and reopen it, the problem goes away until I use the Find function again (which I have learned not to do). It does not always happen, but if many windows are open, it is more likely to occur. I don't have a CAR # for this, because I can't always reproduce it. Bruce, does this match anything you experienced? HI I am working now full time with LabVIEW 2010 on XP and I have found the Find operation (not from the Project, but just from the IDE) a great deal faster than in my previous version LabVIEW 8.2.1. We all had the problem you described with 8.2.1, but not with 2010. I did find the Beta 2010 very slow and unresponsive and I felt the original release was poor but after installing the f2 patch, I am very pleased with 2010. We are working with about 1500 - 2000 VI project with source & compile code separated. The only slow part is the original load of the code, I tend to clean out the cache each morning, then load up the top level and wait for that first time consuming compiling stage but after that, it is OK for me. I will say that I never run will the LabVIEW project explorer open, I really provides nothing for me (I know that a whole other thread), we only use the Project explorer when we do a build and that is automated just to use the Project Explorer configuration. cheers Dannyt Quote Link to comment
ShaunR Posted February 10, 2011 Report Share Posted February 10, 2011 I will say that I never run will the LabVIEW project explorer open, I really provides nothing for me cheers Ditto Quote Link to comment
jgcode Posted February 10, 2011 Report Share Posted February 10, 2011 I will say that I never run will the LabVIEW project explorer open, I really provides nothing for me Off the top of my head I can think of a few reasons I like to (or have to) use Projects: Individual application instances (avoiding collisions) Working on targets e.g. Real Time and FPGA - I don't think there is any way around that You need to deploy Shared Variables from a Project, you can't do it just from the Library Creating Libraries/Classes/X-Controls Configuring Inheritance So I am the opposite, I rarely don't use them (by choice or otherwise) 1 Quote Link to comment
george seifert Posted February 10, 2011 Author Report Share Posted February 10, 2011 George, Are you having the Project Window opened? If so, try to open the VI direct without the project, does this speed up the performace? There was a bug NI fixed in 2010 to solve this, but I'm not sure it solved all Slow Editing issues. Cheers, Mikael I always work withing a project. Since I often have two projects opened this is the only way to go. I tried a large VI without loading the project and editing seemed fine. So I opened the project and edited the same VI. The response time was about the same. This makes me wonder if it's some kind of system issue. My memory usage was about where it normally is so that probably isn't the cause. George Quote Link to comment
mje Posted February 10, 2011 Report Share Posted February 10, 2011 Likewise. Long live the projects. Another reason I use them is the virtual organization of my project items is usually different than their physical location on disk. As George mentioned, I'll sometimes have multiple projects open as well, which would cause problems for VIs common between the projects otherwise. I also don't think you can manage distributions without projects, though I've honestly not tried outside of a project. If the project explorer is to blame, abandoning it is not an option with my workflow habits. After upgrading once I saw similar slow down problems, and tracked it down to my LabVIEW Data directory defaulting to a network location, moving it to a local location mitigated all the issues. This doesn't seem to be the cause of the issue now though. As for system depen Quote Link to comment
george seifert Posted February 10, 2011 Author Report Share Posted February 10, 2011 After upgrading once I saw similar slow down problems, and tracked it down to my LabVIEW Data directory defaulting to a network location, moving it to a local location mitigated all the issues. This doesn't seem to be the cause of the issue now though. As for system depen What happened? Did you fall asleep while typing? I'm confused. First you said moving the data directory helped, but now it's bad again. What happened? George Quote Link to comment
mje Posted February 10, 2011 Report Share Posted February 10, 2011 LOL, no, just incrementally losing a bit of my sanity each day. What I meant is with previous upgrades of LabVIEW (2009, etc), I saw an issue that was traced back to a networked data directory. Making the data local solved all problems for these versions. But with 2010, the slow down does not seem to be related to that, even with my data directory being local, I still often see a short jitter each time I drop something on the diagram. I'll comment that it is not happening right now though, maybe it overheard me talking about it? I really don't want to beat a dead horse, but I think it has to do with the instability of the 2010 IDE. Maybe it gets worse with time, I don't know? Often times the jitter is a preface to a crash... Quote Link to comment
bmoyer Posted February 10, 2011 Report Share Posted February 10, 2011 (edited) I have noticed that if I do a Find operation in the LabVIEW Project, and the project is large, then any change makes LabVIEW unresponsive for 30-120 seconds, and the Z-order of the open windows is shuffled around. This does not include "Find and Replace" (ctrl-F in a VI) or "Find All Instances (right-clicking on an icon) but does include "Find in Project" (Crtl-F in an open project) or "This VI in Project" (Ctrl-shift-E) in a VI. If I close LV and reopen it, the problem goes away until I use the Find function again (which I have learned not to do). It does not always happen, but if many windows are open, it is more likely to occur. I don't have a CAR # for this, because I can't always reproduce it. Bruce, does this match anything you experienced? I'm not sure what causes the saving of VIs to take a long time and I'm not usually aware of my exact sequence of events before the problems occurs. I did try to find in the project and it does take about 30 seconds to find a VI but I didn't notice a save problem afterwards, just that the find is very slow. Actually, with a little more investigation, my statement above is wrong and that if I change any logic on the diagram the save takes about 20 seconds. I didn't notice a delay earlier because I was just moving objects on the diagram, which doesn't cause a recompile. If I change the logic, I don't even have to do a find in order to cause the slowness problem. Bruce Edited February 10, 2011 by bmoyer Quote Link to comment
Ton Plomp Posted February 10, 2011 Report Share Posted February 10, 2011 Are you using the integrated SCC-interface? If your interface is slow (and it can be slow partly caused by LabVIEW) it can hog LabVIEW. Ton Quote Link to comment
MikaelH Posted February 11, 2011 Report Share Posted February 11, 2011 I will say that I never run will the LabVIEW project explorer open, I really provides nothing for me (I know that a whole other thread), we only use the Project explorer when we do a build and that is automated just to use the Project Explorer configuration. You should start looking into OO programming :-) Quote Link to comment
ShaunR Posted February 11, 2011 Report Share Posted February 11, 2011 (edited) You should start looking into OO programming :-) Text Output Object Edited February 11, 2011 by ShaunR Quote Link to comment
bmoyer Posted February 11, 2011 Report Share Posted February 11, 2011 Are you using the integrated SCC-interface? If your interface is slow (and it can be slow partly caused by LabVIEW) it can hog LabVIEW. Ton I do use the SCC with LabVIEW (Visual Source Safe). What do I have to do, disable integrated SCC in LabVIEW? It seems that there are so many don't do this or don't do that (don't have the project open, don't use 32-bit PCs, don't use the Find feature, etc.) in order to have LV2010 work properly. Bruce Quote Link to comment
Ton Plomp Posted February 11, 2011 Report Share Posted February 11, 2011 I do use the SCC with LabVIEW (Visual Source Safe). What do I have to do, disable integrated SCC in LabVIEW? It seems that there are so many don't do this or don't do that (don't have the project open, don't use 32-bit PCs, don't use the Find feature, etc.) in order to have LV2010 work properly. Bruce What I have seen is that LabVIEW is requesting every VI one by one at the SCC portal followed by a burst were all the VIs are checked again... Strange, but that could harm the speed of your LabVIEW. But mostly I have seen this when opening a VI with a lot of dependencies in user.lib. Ton Quote Link to comment
george seifert Posted February 11, 2011 Author Report Share Posted February 11, 2011 Are you using the integrated SCC-interface? If your interface is slow (and it can be slow partly caused by LabVIEW) it can hog LabVIEW. Ton No, I haven't implemented that yet. Quote Link to comment
Michael Aivaliotis Posted February 12, 2011 Report Share Posted February 12, 2011 I've seen this delay before, but not LV2010. I've seen this in LV2009. It happened only in one project of mine. I tried several things to debug it and came to the conclusion that it was due to the complexity of the VIs and not the entire project. Editing some VIs was faster than others. Here's a video showing this: <object id="scPlayer" width="375" height="268" type="application/x-shockwave-flash" data="http://content.screencast.com/users/Michael_Aivaliotis/folders/Hidden/media/3ad6b147-09ef-4725-aaf6-610d3485d736/jingswfplayer.swf"> <param name="movie" value="http://content.screencast.com/users/Michael_Aivaliotis/folders/Hidden/media/3ad6b147-09ef-4725-aaf6-610d3485d736/jingswfplayer.swf"> <param name="quality" value="high"> <param name="bgcolor" value="#FFFFFF"> <param name="flashVars" value="thumb=http://content.screencast.com/users/Michael_Aivaliotis/folders/Hidden/media/3ad6b147-09ef-4725-aaf6-610d3485d736/FirstFrame.jpg&containerwidth=375&containerheight=268&content=http://content.screencast.com/users/Michael_Aivaliotis/folders/Hidden/media/3ad6b147-09ef-4725-aaf6-610d3485d736/00000023.swf&blurover=false"> <param name="allowFullScreen" value="true"> <param name="scale" value="showall"> <param name="allowScriptAccess" value="always"> <param name="base" value="http://content.screencast.com/users/Michael_Aivaliotis/folders/Hidden/media/3ad6b147-09ef-4725-aaf6-610d3485d736/"> Unable to display content. Adobe Flash is required. </object> I do use the SCC with LabVIEW (Visual Source Safe). What do I have to do, disable integrated SCC in LabVIEW? It seems that there are so many don't do this or don't do that (don't have the project open, don't use 32-bit PCs, don't use the Find feature, etc.) in order to have LV2010 work properly. Bruce I don't know what all you guys are talking about. All of this feels like superstition. Don't walk under a ladder or else you get bad luck. Gimme a break. Quote Link to comment
mje Posted February 14, 2011 Report Share Posted February 14, 2011 Here's a video showing this: Yes, that's exactly what I'm seeing. For me though it happens regardless of VI complexity, though they always reside in a very complex project. It's becoming very frustrating. Quote Link to comment
