Running .bat file with labview
Brainiac
Hi everyone,
It's all said in the title.
I wanna run a .bat file with Labview,  i have used the system exec Vi but it didn't work.
However when i run the script directly, it works. Can u help me with this issue
Attached, my code
thanks in advance
Your file doesn't exist, or you typed it wrong.  I just did a test where I made a batch file with ping localhost as the only thing in the file then did the same thing you did and it worked.  I'd suggest putting an output on your error, and Standard Error to see if it returns anything like file not found.  Also you may want to test small with a batch file like dir or ping.
I remember that I had to change my code using the "cmd /c" when changing over to Win10 from Win7.
Before I didn't have the "working directory" wired instead I specified the full path in the command. e.g. cmd /c "c:\Temp\file.bat"
Are you running WIn10?
@Brainiac did you solve this in the end?
The code below shows how I do it, this works completely fine for me on Windows 7..10.
The Generation Batch File is the complete path on disk, I don't use the Working Directory input.
  On 9/13/2019 at 12:32 PM, hooovahh said:
The only thing to add to Neil is that the Wait Until Completion should be True if you are going to read the standard output after it is complete.
Expand
Indeed.
In my circumstance though, I don't really care too much for the output, I have some downstream code that waits a bit and checks for correct generation of a PDF file I am creating.
