Wiring the 'N' terminal inside a For Loop
Our local users' group last night had a presentation based on the Tips and Tricks to Speed LabVIEW Development session from NIWeek. Since I missed that one at the conference, I went. On one of the slides, there was a new (to me) tip that wasn't part of the presentation.
You can use the N terminal of an auto-indexing For Loop as a proxy to the size of the (smallest) incoming array. All these years, I've been manually calculating the Array Size outside the loop!
post-2992-1189602836.png?width=400
Of course, it's obvious now that I've seen it. Am I the last person in the world to learn this? :lightbulb:
EDIT: This was supposed to go in the LabVIEW (General) forum, but in my excitement I posted it in the wrong place. :(
  • Replies 70
  • Created
  • Last Reply
Top Posters In This Topic
QUOTE(Justin Goeres @ Sep 12 2007, 08:17 AM)
No, you're not the last person in the world to learn this. I am. Thanks for sharing the information, I didn't get to attend that session at NIWeek either.
QUOTE(Justin Goeres @ Sep 12 2007, 09:17 AM)
I reacted the same way when I saw someone wire an enum to a format into string. I thought it was great but everyone else said "You didn't know that?"
I think this is not our short-coming but rather due to the sparse upgrade notes. I religeously read every one of these cover to cover and still I miss stuff.
WE really need EXHAUSTIVE upgrade notes!
Ben
QUOTE(Ben @ Sep 12 2007, 09:40 AM)
I don't think that would've helped for your enum example nor Justin's wire-the-N. Those have been in LabVIEW for a long long time.
QUOTE(Aristos Queue @ Sep 13 2007, 12:32 AM)
I've actually received a product suggestion that said "LabVIEW should have a better way to calculate the size of an array".
There's a better way? :blink:
QUOTE(ragglefrock @ Sep 12 2007, 11:23 AM)
I prefer this method of getting an array's size.
Oooh, now that's so "clever" it's downright scary. I would have NEVER thunka' that as an alternative. :P
Dave
QUOTE(crelf @ Sep 12 2007, 08:06 AM)
I think AQ's "friend" didn't realize there was an "Array Size" function built into LV, and was calculating them him/herself with the method shown.
Jaegen
QUOTE(jaegen @ Sep 13 2007, 02:13 AM)
I was kidding :D
QUOTE(Ben @ Sep 13 2007, 03:30 AM)
It could be worse! The customer could have sumbitted the following code to find array size.
What the? :blink: Can you talk us through it?
@Ben: Could you tell me what is the format into string VI? :) I don't know about this :P . I have to you the property strings[] and array indicator to get the string of an enum.
@All: You guys are experts in LabVIEW, so if you have time, it's really helpful if you can list down these tricks in VI. I really want to learn more about these stuffs. It's hot :thumbup: .
Thang Nguyen
This gives me an idea for kind of a cool thing to do. Not a Coding Challenge exactly, but more like a Cleverness Festival! :beer:
We could pick an interesting trivial problem (Array Size is a really good one) and challenge LAVA members to find original (not optimal) ways to solve it. We could constrain it with a few simple rules like
  • Must not use any subVIs except those provided in vi.lib or OpenG.
  • All code must fit in a block diagram window of a certain size (and no stacked sequences!)
  • All code must obey basic LabVIEW style conventions
or whatever. I'm just brainstorming here. Might be fun to see what's lurking in the corners of our brains.
QUOTE(Thang Nguyen @ Sep 12 2007, 11:31 AM)
Welcome to The Cool Kids' Club: :P
http://lavag.org/old_files/monthly_09_2007/post-2992-1189622895.png' target="_blank">post-2992-1189622895.png?width=400
Format Into String is in your String palette.
BTW, there's a more versatile Get Strings from Enum function in the OpenG Data Tools library. It takes a variant as input, so you're not limited to using it with just one enum.
QUOTE(tcplomp @ Sep 12 2007, 03:17 PM)
RE: My array size example
"If you want people to respond, say something rediculous." (Ben)
The Interesting Stuff thread that Yen started on NI has lot of links to LV trivia.
For obfuse code see the thread that Christian started. It has examples that range from the simple to the subtle.
Ben
QUOTE(Justin Goeres @ Sep 12 2007, 02:49 PM)
I think an even lesser known trivia is to use Scan from String to read an enum string
post-447-1189626665.png?width=400
I believe I can authoritatively say no, you weren't the last. Now, am *I* the last person in the world to learn this?
For some reason, I knew you could wire the N terminal inside a For loop, but doing it in the case of an auto-indexed loop never occurred to me.
