Feelings on Icons for Terminals?
I was just reading some opinions on NI.com about whether it is better to show FP terminals on the block diagram as full-sized 32x32 icons or as the smaller 16x32 terminals. I wondered what people on LAVA think. Do you use one type or the other and how strongly do you feel about it? Personally I (moderately strongly) prefer icons.
-- James
Definitely the small terminals. I remember when I first took an NI training course (running LabVIEW 2009 I think) and saw all these huge terminal icons. I had been using LabVIEW 7.1 exclusively up to that point, and didn't know what they even were at first. Like asbo, one of the first things I change when I do a fresh install.
The only case that I've seen where they provide something extra is they display whether you have a chart/graph indicator or just a "plain" array or waveform indicator. Still not enough to make me use them, but it's something...
Oh dear, 5 to 1 against so far. Surely there are some more unicorns?
Additional question (motivated by the ni.com discussion): do you think having both forms leads to confusion, and would you be in favor of LabVIEW being changed to allow only one form? For the purposes of this question, assume the form to be chosen is the other one from the one you like.
-- James
Edited by drjdpowell
Just wanted to chime in and put a vote in for non-icons. Again I've never known anyone to prefer them.
I don't use express VIs often, but when I do I always change them to the icon view and remove the caption. Probably to save on block diagram space.
+1
The only time I see icon terminals are when someone new to LabVIEW starts programming, but then it is only because icons are the LabVIEW default.
/J
I usually use the small terminals, although I'll sometimes use icons for typedefs (because the typedef's icon is shown). This works equally as well for cluster icons on the BD that are typedefs. So I guess you could put me down for my usual "it depends" half vote yes, half vote no.
I hate large icons. Aristos Queue loves them. If I had my way, they would have been gone long ago. Unfortunately, AQ always argues to keep them around. But since he's so badass in just about everything else he does around here, I'll pick my battles elsewhere. ;)
If I count right that's 9.5 to 1.5 (2.5 if you count AQ).
Let's look at one of my more recent subVIs:
post-18176-0-84452700-1319643931_thumb.p
I choose this one because it has 8 total controls/indicators, which is more than most.
The first thing this illustrates is that I use a lot of LVOOP objects, of more than one type, and a little thing that says "OBJ" really isn't that useful for easily identifying the object.
The second thing is that in subVIs, the terminals are all (or mostly) the inputs and outputs of the VI, and I place them on the outside, with plenty of space for a larger icon. Even if the icons were just bigger versions of the smaller terminals, I would still consider them superior, because inputs and outputs should stand out and draw the eye.
This example also shows what is probably the highest density of Front Panel terminals on any of my VIs. My User Interface VIs tend to use event structures and subpanels and a relatively small number of "big" controls/indicators. "Big" in the sense that they do a lot, like a Multi-column Listbox with an extensive list of Right-Click Menu options, or a Text box that holds a summary of a large amount of information, or an Xcontrol. So I seldom have a need to pack controls in densely. In fact, the terminal icons are sometimes just sitting, unwired, near the event structure, acting more as graphical documentation than actual code. This documentation is important, because most UI control/indicators are major parts of the VI, and I want their presence to stand out on the diagram.
To be devils advocate, if your fighting for space to fit yet another not-very-important indicator nested somewhere deep in a tight diagram, then your not coding as clearly as you could. :)
-- James
I greatly prefer the icons (as James knows) because:
1) They are easy to see. I am very focused on the interface and I want the terminals to stand out.
2) They sometimes contain additional information, and I consider them more aesthetically pleasing.
3) Saving space is not a concern because of the way I design my applications. A class method (and very nearly all my VIs are methods in classes) usually has the terminals for the owning class, error terminals, and maybe an additional input or output (occasionally a couple of each). I have plenty of room for these on the block diagram, and I want them to be highly visible.
  • Like 2
<snip>
-- James
Yup. But my style is to have control labels to the left, indicators to the right and for them to be stacked closely to lessen wire bends.Of course. I don't suffer as much from the "obj" problem :)
I always enjoy this discussion. First of all, no need to feel bad for James. If you follow the other discussions, you know if anything happens he will have the last laugh.
If you have OCOOD (obsessive compulsive OO disorder), then it is likely you also suffer from I-have-two-primitives-wired-together-here-better-create-a-subVI syndrome. This results in a lot of time spent with the icon editor and plenty of whitespace to fill with terminals. I do not mind the iconified terminals so much in that case.
Most times I worry more about blazing speed than reuse, so I have a dense coding style. My biggest problem with the icon view is that they take a lot of space and give little information back in return. Do I really need to see a little stop button icon when I am wiring to a boolean labelled Stop?. The exceptions are XControls, Graphs and Charts, I tolerate icons for those (when I give a darn, which is not often).
I once submitted an idea to provide an option to de-Expressify the Express VIs so I could drop them in peace (no popup, icon view, no caption) but it was shot down in flames. Fortunately I only use two of them so I settle for Merge VIs on the palettes.
Speaking of Express VIs, I will say that I see more use in the Block Node View of SubVIs than I do in the Icon View of terminals. Of course by that I mean epsilon > 0.
Edited by Darin
Nope. That's the ARCLD (Analy retentive classical labview disorder). Those with OCOOD have to create a class project, sub-vis for all the methods and fill out a multitude of dialogues.
*Exactly*! If the icon shows something useful (other than just the datatype, which is shown on the terminals anyway) then it's often appropriate to show the icon.
Terminals, definitely. It's one of the handfull of settings I immediately change with a fresh LV install. (Along with branching dots, constant folding, and a few others.)
...because inputs and outputs should stand out and draw the eye.
I disagree. Emphasizing the inputs and outputs distracts me from what I'm really interested in, which is what the code is doing. Terminal icons are too similar in shape and size to sub vi icons, and to a lesser extent class constants.
When I look at the diagram you posted it's hard to quickly identify where the vis are. The first couple times I glanced at it I didn't even notice the final Msg method outside the case structure--it was lost in the noise. In contrast, I easily identified all the sub vis in Shaun's diagram.
