orko Posted April 12, 2008 Report Share Posted April 12, 2008 Well, the "special" MCL that PJM extracted is definitely not the same beast as any MCL that I've tried (even back to LV6.0). Just look at what happens when you play with the "Symbols Visible" boolean... Download File:post-3266-1207897024.vi From this, it looks like the special MCL is 0-based for the "Symbols Visible" active cell column, while any other MCL is base-1. Somewhere out there, there was a MCL that behaves differently than all the rest. Maybe someone who has an older version of LV can check it out...when was the MCL introduced? Of course, this may be a control that never made it out of NI's door...and was just used in compiled code. Quote Link to comment
Ton Plomp Posted April 20, 2008 Report Share Posted April 20, 2008 QUOTE (PJM_labview @ Feb 11 2008, 10:12 PM) I have made some progress on that front. I extract that control from the example finder (this turn out to be a MCL listbox). Thanks, for this serious hacking! QUOTE (PJM_labview @ Apr 10 2008, 10:28 PM) PS: Now, go give your $10 to LAVA I made it a 20 (a lousy €13). Does anyone have an idea why NI wouldn't release this MCL (as an XControl?) Ton Quote Link to comment
Norm Kirchner Posted July 26, 2008 Report Share Posted July 26, 2008 Well boy didn't this thread die out. I've got something for y'all to ponder the pojundery Should/Could we try to get the same functionality out of the other columns in a tree control? I've got a situation where having glyphs or indentations in those other columns would come in handy. I realize I could try to do this w/ 2 separate tree controls or a variety of combination's, but to pull it off in 1 control would be pretty darn cool!! Quote Link to comment
Lerosbeef Posted August 11, 2011 Report Share Posted August 11, 2011 (edited) I can only download François Normandin's last attachment. All the other important attachements don't work, too old? Edited August 11, 2011 by Lerosbeef Quote Link to comment
Popular Post PJM_labview Posted October 16, 2012 Author Popular Post Report Share Posted October 16, 2012 Here is the MCL control again (since the previous links in the Thread are broken). Thanks special MCL.vi 4 Quote Link to comment
Fab Posted August 27, 2013 Report Share Posted August 27, 2013 This is an old thread, so I understand if nobody answers I need to be able to have check boxes in multiple columns, in my case 12 columns. I tried the MCL control that PJM found and I was able to get the symbols to show in 8 columns, more than that does not work. Any ideas how to get this done? I could always go back to the hack of old days of using the Symbol font and show the check box this way, but I want to see if there is better way. Thanks, Fab Quote Link to comment
MikaelH Posted August 27, 2013 Report Share Posted August 27, 2013 This is an old thread, so I understand if nobody answers I need to be able to have check boxes in multiple columns, in my case 12 columns. I tried the MCL control that PJM found and I was able to get the symbols to show in 8 columns, more than that does not work. Any ideas how to get this done? I could always go back to the hack of old days of using the Symbol font and show the check box this way, but I want to see if there is better way. Thanks, Fab ..or just use the old nice Picture control, lot of fun work though :-) Quote Link to comment
Fab Posted August 27, 2013 Report Share Posted August 27, 2013 ..or just use the old nice Picture control, lot of fun work though :-) The problem is that I need it inside a table. Thanks for replying, it was nice to see you at NI Week. Fab Quote Link to comment
MikaelH Posted August 28, 2013 Report Share Posted August 28, 2013 Or could the table be replaced by a picture control :-) It was nice to see you too. Cheers, Mike Quote Link to comment
Mellroth Posted August 28, 2013 Report Share Posted August 28, 2013 The problem is that I need it inside a table. Thanks for replying, it was nice to see you at NI Week. Fab I think this is the originally posted MCL, but with code to display symbols in a specified number of rows-columns. MultiColumnListbox with MultiColumnSymbols.vi /J 1 Quote Link to comment
Fab Posted August 28, 2013 Report Share Posted August 28, 2013 I think this is the originally posted MCL, but with code to display symbols in a specified number of rows-columns. MultiColumnListbox with MultiColumnSymbols.vi /J Thank you so much! I see what I did wrong, I was trying to set the symbols for the entire row at once and I was only getting the first 8 columns populated. Doh! I needed to set one cell at a time inside the for loop. Thanks again, Fab Quote Link to comment
David Koch Posted July 7, 2015 Report Share Posted July 7, 2015 (edited) I think this is the originally posted MCL, but with code to display symbols in a specified number of rows-columns. MultiColumnListbox with MultiColumnSymbols.vi /J Here's the corrected version that behaves correctly, delete symbols if you decrease rows/colums between two run and actually displays the right symbol front of the corresponding number. LV 2013SP1 David Koch MultiColumnListbox with MultiColumnSymbols corrected.vi Edited July 7, 2015 by David Koch 1 Quote Link to comment
hooovahh Posted July 7, 2015 Report Share Posted July 7, 2015 Because recursion is fun, here is the link to the idea exchange to make this official. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Symbols-on-all-columns-of-a-multicolumn-listbox/idc-p/3161734 Quote Link to comment
Franco Atzeni Posted March 1, 2018 Report Share Posted March 1, 2018 On 12/4/2008 at 0:59 AM, Francois Normandin said: QUOTE (tcplomp @ Apr 10 2008, 02:48 PM) Well, I can't say there is a difference either. I can even reproduce your error! I compared a new MCListbox with the one in PJM's VI and I get two different results... I can see from the coercion dots that they're not the same type. That seems a clue. However, I haven't found yet what's the difference. Hopefully, a good night of labview dreams will get me on track. Download File:post-10515-1207863359.vi (version 8.5) I've tried this example, but it seems doesn't works. I use LV 2016 thanks! Franco Quote Link to comment
ShaunR Posted March 26, 2019 Report Share Posted March 26, 2019 Does anyone know of a version of this control that can have a transparent background? Quote Link to comment
hooovahh Posted March 26, 2019 Report Share Posted March 26, 2019 Does anyone know of a version of this control that can have a transparent background? Here is a Classic MCLB which can have its cells be transparent, and have symbols in all columns. System controls can't be colored, and the modern one I couldn't get to be transparent. It might be possible but the classic was easy. MCLB Symbols In All Columns Transparent.vi 1 Quote Link to comment
ShaunR Posted March 26, 2019 Report Share Posted March 26, 2019 Here is a Classic MCLB which can have its cells be transparent, and have symbols in all columns. System controls can't be colored, and the modern one I couldn't get to be transparent. It might be possible but the classic was easy. MCLB Symbols In All Columns Transparent.vi 6.57 kB · Almost. The classic one cannot change the colour of the scroll bars. I think I need a modern one (which can be changed). Quote Link to comment
hooovahh Posted March 27, 2019 Report Share Posted March 27, 2019 Attached is an updated one with classic and modern MCLB, transparent cells, and glyphs in all cells. MCLB Symbols In All Columns Transparent.vi 2 Quote Link to comment
ShaunR Posted March 27, 2019 Report Share Posted March 27, 2019 Attached is an updated one with classic and modern MCLB, transparent cells, and glyphs in all cells. MCLB Symbols In All Columns Transparent.vi 6.89 kB · Perfect. Thanks hooovahh. Did you use flarns tool? Quote Link to comment
hooovahh Posted March 27, 2019 Report Share Posted March 27, 2019 Perfect. Thanks hooovahh. Did you use flarns tool? No. For the transparent-ness I customized the control in the control editor, moved the cells a little to reveal the back which was a shade of grey. I colored it transparent, then moved the cells back to where they were, then painted the white cells transparent. For the glyphs, if you have an INI key you get a right click menu on MCLB that is you Enable Glyphs In All Cells, I think the INI is EnableSecretPopups=True. Then you can enable it for any MCLB, and I think tree. It also gives other menus like having parts of a button move or grow with a button as it is resized. Quote Link to comment
ShaunR Posted March 27, 2019 Report Share Posted March 27, 2019 I think the INI is EnableSecretPopups=True. Then you can enable it for any MCLB, and I think tree. It also gives other menus like having parts of a button move or grow with a button as it is resized. Ah. It seems the ability came in in 2011 (was working in 2009). I was opening your controls in 2018 and back-saving to 2009, so it seems these features that are enabled are preserved with back-saving, which is useful to know. Also, I didn't realise that we now have a way (via ini-file) of making these controls multiple glyphs-I missed that memo (your link). So thanks again. Quote Link to comment
mcduff Posted September 24, 2019 Report Share Posted September 24, 2019 I think the INI is EnableSecretPopups=True. Then you can enable it for any MCLB, and I think tree. It also gives other menus like having parts of a button move or grow with a button as it is resized. Excuse my stupidity, but I put that "EnableSecretPopups=True" in my INI, but still cannot find the option to enable multiple symbols in a MCLB. Not sure if I am looking in the wrong spot or if I need another INI key. Thanks mcduff Quote Link to comment
Sam2004mai Posted October 1, 2019 Report Share Posted October 1, 2019 Why this website suffers from broken links i cannot download any of post linked examples. can anybody help post again the MCL example with multi Glyph. Quote Link to comment
Antoine Chalons Posted October 1, 2019 Report Share Posted October 1, 2019 (edited) 6 minutes ago, Sam2004mai said: Why this website suffers from broken links i cannot download any of post linked examples. can anybody help post again the MCL example with multi Glyph. I can download the files from this thread just fine. I'll try sending you a private message with the VI Edited October 1, 2019 by Antoine Chalons Just sent private message with file as an attachement, hope this helps Quote Link to comment
hooovahh Posted October 1, 2019 Report Share Posted October 1, 2019 Well some of these posts are from 11 years ago, and there have been lots of back end changes since then. We try to keep all the content we can but in some migrations things are lost. That being said I can download the newest attachments. A while ago before I was a moderator there was a pretty catastrophic crash with all content of the forum being lost. One such awesome engineer realized he had setup subscriptions to the forum, and would get an email for every reply someone made. Because of this he had a record of all communications made on the forum and provided it to the site admin. I wasn't a mod then so I don't have all the details but with the help of Michael and this guy they were able to bring back lots of the old content as LAVA 1.0 Content which you'll see from time to time. I'm unaware of what happened to attachments then, but I assume they were all lost, or manually reuploaded. Edit: Here's more info on the crash. Quote Link to comment
